I'm needing a spring clip that fits on the end of a Driveshaft, S1 Rover outer.
Anyone any ideas where i would get one ?
Alan
Driveshaft Spring Clip
Re: Driveshaft Spring Clip
I have some ~50K miles S2 drive shafts - I don't know whether the outer changed? You're welcome to cannibalize one if it's compatible ...
Think I have one or two outers Alan.
Pretty sure this is an S1 outer Alan as I never upgraded on my cars.
Thanks Robin/Tut.
I forgot about your chest of driveshafts Tut. Can I pop over and take one (clip that is) ?.
Me and Cheez (mainly Cheez) replaced my outer C.V gator but damaged the clip when removing the outer joint. I didn't have a spare so bent it back into shape so i could attend the trackday.
Alan
Alan
That's fine Alan, just make sure that it is the correct spline pattern/diameter, as I have a rogue outer CV joint that is different than the others.
tut.
ps if you come over could you remember to bring the tent.
tut.
