S2 plastic dashtop removal
neilj37
Post by neilj37 » Thu Sep 02, 2010 10:27 am
For some strange and unknown reason my dashtop appears to have warped in the heat the other week so I want to replace it / fix it. Tried to get it out but for some reason it won't budge. I have removed screws at either end and screws in vents but it still won't lift out.
Any guidance is gratefully appreciated.
Elise S - OMG its fast spec
Seat Leon FR+ Supercopa - BTCC Spec
MX5 Mk1 - turbo build spec
bertieduff
Re: S2 plastic dashtop removal
Post by bertieduff » Mon Sep 13, 2010 11:29 pm
Any luck with it?
It's a while since I've done this, but if you've got the end screws and popped out the vents it should have lifted out no bother... :scratch
neilj37
Post by neilj37 » Tue Sep 14, 2010 12:13 pm
No still not got it out. I think the vent housings are somehow stuck in the foam underneath (ie very tight fit). I don't want to force it incase I break something. Might just bite the bullet and buy a new top then it doesn't matter if I trash the other one taking it out.
