Humming noise when reversing slowly
The_Rossatron
Post by The_Rossatron » Tue Jul 18, 2006 9:53 am
I get a deepish humming noise when i reverse slowly, pretty sure its coming from the back of the car. Brake binding perhaps? Doesn't do it going forwards though? Any thoughts?
ta
http://www.allflashnocash.com
Post by Shug » Tue Jul 18, 2006 11:29 am
It's not just the gearbox whine is it? PG1s are noisy beasties and get noisier if there's less oil in there. Does it rattle like f**k on idle? (you can tell if it's gearbox, by pressing the clutch in at idle - the noise that dies away is the 'box :D)
The_Rossatron
Post by The_Rossatron » Tue Jul 18, 2006 11:32 am
Tried pushing the clutch when the noise was happening but it stayed there. Sounds more like something rubbing against something else, or something is too tight. :shock:
Post by Shug » Tue Jul 18, 2006 11:41 am
The_Rossatron wrote:Tried pushing the clutch when the noise was happening but it stayed there. Sounds more like something rubbing against something else, or something is too tight. :shock:
While you were reversing? It would still make a noise as the 'box is still turning, it's just disconnected from the engine.
I meant to check stationary at idle, to see if the box was overly noisy. If it's chuntering away like a mad thing, it might be a wee bitty light on oil.
Yours is a Rover engine, right?
Has it always done it, or is it a new noise? - if it's always done it, it's 99% likely just to be a noisy reverse gear.
If it's something rubbing, it would likely do it in first too - the rear pads tend not to move about like the fronts, but I suppose it is a possibility....
