Door won't close on Exige
B12ANR
Post by B12ANR » Mon Oct 11, 2010 8:13 pm
Quick question... i've had my car a week now and my drivers door doesn't close first time until (i assume) the car body warms up during the day. It only happens in the mornings hence my prior assumption. Has anyone experienced this phenomenon?
Modena Scotland
Re: Door won't close on Exige
Post by Modena Scotland » Mon Oct 11, 2010 8:21 pm
No.
A Senna
Shared SE Calendar
vxc
Post by vxc » Mon Oct 11, 2010 9:04 pm
you can check the stud bolt , it can be adjusted by loosening it slightly, it may be that,
B12ANR
Post by B12ANR » Mon Oct 11, 2010 9:37 pm
vxc wrote:you can check the stud bolt , it can be adjusted by loosening it slightly, it may be that,
Cheers bud, i'll give that a go :thumbsup
dirkpitt
Post by dirkpitt » Tue Oct 12, 2010 4:17 pm
it could be the striker pin is too long and catching......you can unbolt it and remove a washer. :thumbsup
1998 Audi Elige s1-1.8t 20v
Post by Andy G » Wed Oct 13, 2010 9:17 am
I seem to remember the catch on the body work on my 111r coming loose, and causing something similar.
I just tightened it up, correcting the work of those slack assed turnip farmers :thumbsup
Noops
Post by Noops » Thu Oct 14, 2010 12:00 am
Kick it into place :wink:
Edin430
Post by Edin430 » Sun Oct 17, 2010 7:50 am
im not taking the p1ss saying this but - are you closing it hard enough? if it's 'closing' to a certain point (i.e. catching the lock but not closing properly - leaves about an inch of space - and you'll know if it's doing this as you won't be able to just pull it open, you'll need to press the button again) then that's you're problem.
if not try looking at the white plastic clip within the door lock when it's open and make sure it's lubed up. it's like a claw - opens round when you push the button in and stays open until you shut the door when it clicks back round.
B12ANR
Post by B12ANR » Mon Oct 18, 2010 11:21 am
Yes is the short answer mate. As mentioned, it closes fine once the car has warmed up (yeah.. seriously!).
Cheers for the lock advice - i'll try lubbing the door again (MMC told me they done this to try to fix it already).
