Throttle Body
Throttle Body
Does anyone know the diameter of the standard fit alloy throttle body as found on the early S2's?
That's what I was thinking the answer would be.
It's interesting that PTP sell a 140 upgrade which comes with the alloy plenium and a 52mm TB - but their 165 kit comes with the alloy plenium but NO TB.
Just wondering if the bigger TB would help with my driveability issues at low speed.
Shyte - I was supposed to be digging out a TB for Mandy's car, wasn't I? TBH, I'd have to measure it, as I can't remember if it's 52 or 48mm......mac wrote:That's what I was thinking the answer would be.
The PTP still uses the MAP sensor, doesn't it? The engine might run a little lean with the 52mm TB, but shouldn't if the PTP uses MAP for fuelling as well as TPS.
If mine is a 52mm, you can always try it with no obligation to buy if it makes no difference
I'm getting worried about you mate - are you going soft in your old age?mac wrote:
man buys PTP 165, SportsCat, ITG, Nitrons, A048s and OZ wheels, ARB... then worries about "low speed driveability"
- The_Rossatron
All S2's have a 48mm alloy throttle body if that helps.
http://www.allflashnocash.com
Ta. Shug if you can dust out that TB that would be great and if its a fix or improvement the I'm sure some beer tokens can be exchanged.The_Rossatron wrote:All S2's have a 48mm alloy throttle body if that helps.
As for the issues - my car kangaroo's on part throttle, which ain't fun or pretty when on hard set nitrons.
Unless the slow speed mapping is overfuelling like a b'stard. Either it could do as you say, or the increased airflow will damp down the pulses from the bigger cams in the plenum and give the MAP sensor a more stable signal to work with.mckeann wrote:the bigger throttle body will make your drivability issues much much worse. Basically, for the same throttle opening at the peddle, the TB will flow more air, and the car will be even jerkier when just trying to manouvere slowly or in traffic jams.
It's worth a try, as the fuelling will be varied by MAP sensor as the PTP uses a piggyback ECU - so the MAP functions of the standard ECU are still trying to read pressure from a manifold that's now filling with pulses from the harier cams....
Just going by experience of running the 285H cam on a plenum for a wee bit. Even with the cam timing set very mild, it had to run waaaay rich to idle, and wasn't happy at low speed. I didn't try with & without the bigger TB, so coudn't say if there was a difference and the Emerald doesn't use the MAP sensor, so it wasn't trying to compensate.mac wrote:as shug said![]()
Just a theory though
