undertray bolt sizes
anyone know what the sizes of the undertray bolts are for the good old S1? Going to replace them with stainless numbers when I have it off again.
Oh, and anyone got a spare 13m ratchet spanner I can borrow in the Edinburgh or Glasgow area?
Cheers chaps & chapesses,
Greg
Greg
Re: undertray bolt sizes
Arf!GregR wrote:when I have it off again.
(sorry)
I'd chuck the M8 dome head ones though and put on some decent hex-head ones. Only a matter of time till you're cold, bored, wet and they are full of grit - then you round off the allen key feckers in five minutes...Uldis wrote:It's M5 x 20mm hex head most of them, let's see 5 at the back, 3 each side plus the 5 that connect to the front undertray.... 16 of those (get 20, you always lose one or two)
And 4 x 20mm M8 dome head (allen)
In the Exige S1 they came already in SS standard...
For the short time I had them, I was forever digging sh*te out of them to get an allen key anywhere near them.....Uldis wrote:Funny, I never had a problem with the allen head, because they're upside down I guess grit just falls off and wet doesn't matter, they're SS and don't round off.
I recently lost one and went to buy another one exactly the same. I like them
You obviously don't drive the car enough mate
same experience here as shug.Shug wrote:For the short time I had them, I was forever digging sh*te out of them to get an allen key anywhere near them.....Uldis wrote:Funny, I never had a problem with the allen head, because they're upside down I guess grit just falls off and wet doesn't matter, they're SS and don't round off.
You obviously don't drive the car enough mate![]()
Right, they work out at about £4 EACH! fill your boots... Or leave them at home and save more weight....Sanjoy wrote:Was actually looking at Titanium ones today to save weight.
I have a ratchet spanner, will a socket set not do?
Good place in Scummers for bolts is White Milne and CO by the Cineworld, real cheap for A-2 stainless (OK it's not the shuttle spec A-4 stuff but it won't rot)
Yeah - but will eat through your undertray twice as quick as Stainless ones (which chew through it quicker than normal ones).
The problem with the dome headed bolts isn't the crud. The allen socket is design to turn the bolt head (and only the bolt head) what normally happens is that the bolt corrodes to the washer and the washer to the undertray - now your trying to turn something with a much wider radius that the bolt was designed for.
You have 2 remidies - 1 - duralac the washers (perfered option)
2- Put a plastic washer between the bolt head and the normal washer (mac option)
either way your cutting out the corrosion issues and the bolt head works against the force it was designed for.
