Parked the car in the garage then noticed some small oily stains on the drive. Checked passenger rear corner and sure enough bottom of the damper covered in fluid which was then running onto the handbrake cable and dripping off same and onto the drive. Had noticed strange noise from that corner recently but thought it was something in the air filter. Now I know otherwise.
I now need to replace either all shocks/dampers or just the back ones. Presently on yellow Bilsteins.
Suggestions please from those who know best. Also what make. Mostly road use but also up to 6 track days per annum.
Is there anything else I should do while replacing, other then the Geo. being an Aberdonian I already perchased the discounted alignment package on Groupon advertised on here last week
Car is an Elise S2, 111R.
Martin
