Toyo R1-R Tyres Anyone using them?
Post by Victor Meldrew » Fri Apr 15, 2011 10:38 am
Has anyone heard if these are any good? Road run, track day tyre purchase immanent.
Re: Toyo R1-R Tyres Anyone using them?
Post by tut » Fri Apr 15, 2011 11:40 am
Plenty using them John.
Good road tyre, fine on track especially in the wet, usual proviso, the more powerful the car and driven hard, they will go off on track much sooner than an R tyre.
Post by Victor Meldrew » Fri Apr 15, 2011 12:12 pm
tut wrote:Plenty using them John.
Ok, more of a replacement for the T1r's than an alternative for 888's then.
tuscan_thunder
Post by tuscan_thunder » Fri Apr 15, 2011 1:46 pm
I have them.
They're a good jump up from T1-Rs, a lot stickier, probably they're as soft in terms of 'sticking your fingernail in' as my Medium compound AO48s.
So far, really, really impressed with them but then my car doesn't have much power.....
I wouldn't bother with R888s/AO48s now unless I was tracking very, very regularly.
Mair throttle, less brake
SAJ
Post by SAJ » Fri Apr 15, 2011 3:51 pm
Hopefuly will have mine fitted this weekend.
Instagram: @RevLimits
SAJ
Post by SAJ » Wed Apr 27, 2011 6:57 am
So had mine on for the last 500 odd miles now. I think they are brilliant. Grip in the dry is excellent, stiffer side walls over the bridgestones does reduce the ride comfort but not by much.
On the limit grip is good too, they don't just snap away but but break away progressively enough that you have plenty of time to catch it. Also the understeer has all gone, but I put this down to having 205s on the front now up from the original 175s.
I've had T1Rs in the past and really liked them but the R1Rs are far superior in everyday except probably When encountering standing water.
