VHPD MAX REV RANGE (190 bhp)
Post by Gareth » Sun May 01, 2011 6:59 pm
Just been playing with the 340R's tach.
I can set the (4) shift lights for the rev range on full throttle.
So what should each light be set to (rpm)? I guess the final light is the most important. I was thinking 7750rpm? Too little/too much?
Tia
G
Gourlay83
Re: VHPD MAX REV RANGE (190 bhp)
Post by Gourlay83 » Sun May 01, 2011 8:46 pm
Gareth wrote:Just been playing with the 340R's tach.
Tia
G
Well, the Caterham has just been lowered from 9200 to 8600 rpm..........
Alan
P.S How did the exam go?
Post by Gareth » Sun May 01, 2011 8:54 pm
Tia
G
Alan
9200....oooft!
8600 seems mighty high too but you've got weight on your side.
roadboy
Post by roadboy » Sun May 01, 2011 9:25 pm
Yeah, 7800 is about as far as you wanna go Gareth.
Dan
SPS Automotive
Independent Lotus Specialists
Gourlay83
Post by Gourlay83 » Sun May 01, 2011 9:38 pm
Tia
G
Alan
9200....oooft!
Obviously the Engine in the Caterahm has a bottom end built for the higher revs, Steel Crank, Forged pistons with fancy rods etc ...
7750 sounds spot on, for a standard VHPD.
Alan
Post by campbell » Mon May 02, 2011 1:20 am
Gareth wrote: So what should each light be set to (rpm)? I guess the final light is the most important. I was thinking 7750rpm? Too little/too much?
Tia
G
How often do you want to rebuild the engine?
Ah...forgot...you won't have it long enough to worry about that, eh! Nor did the last two owners, before you say anything ;-)
