was :electrical problems S1 elise now :bulb holders
Post by BiggestNizzy » Mon May 02, 2011 1:17 pm
Really had to get my finger out since I suffered HGF on the clio so the elise got fired up this morning, everything seems fine except, it won't start on it's own (I will take the battery out tommorow night and charge it (going out for some lunch now as I am holiday) and when you switch things on some things go off (I put it in reverse and the dash switched off) also when I switch the blower on the temperature jumps (on full gets 999 degrees) my guessing is a combination of battery low and some rusty connector.
any other ideas ?
Re: electrical problems S1 elise
Post by robin » Mon May 02, 2011 1:29 pm
Earth straps, front or rear.
Use a long jump lead (or two short ones clipped together) and connect the battery -ve terminal to the engine block somewhere and see whether that makes things better; if it does, deffo earthing problem.
Post by BiggestNizzy » Tue May 03, 2011 10:58 am
Where is the earthing strap at the rear ?
Post by robin » Tue May 03, 2011 11:56 am
Pax side to gearbox, dangles around near where the coolant return rails exit the chassis.
Post by BiggestNizzy » Tue May 03, 2011 10:58 pm
Replaced some earth cables up front and the car started off another battery, original battery is on charge and off for an MOT tommorow night.
Post by BiggestNizzy » Wed May 04, 2011 6:55 pm
Fired up today first time and everything works again - woo
Thanks again robin
Post by BiggestNizzy » Wed May 04, 2011 10:54 pm
HELP!
I need to know what type of tensioner my car has It is a 98 S1 elise but it had a 135 head and cams fitted a few years ago and it changed, going to order a new tensioner and cam belt and the car is sitting 9 miles away (up hill no so cycling to find out)
TIA
Re: was :electrical problems S1 elise now :what tensioner
Post by robin » Thu May 05, 2011 8:37 am
Assuming it still has the head from my car fitted it will have been an automatic tensioner.
Post by woody » Thu May 05, 2011 11:48 am
BiggestNizzy wrote:HELP!
TIA
Are you doing the belt? I have the tools if you need, welcome to do it at mine.
Post by BiggestNizzy » Thu May 05, 2011 12:23 pm
TIA
Having my verniers fitted (eventually) and getting a man to do as I just don't have the time. Car is in getting serviced and MOT'd
Post by BiggestNizzy » Thu May 05, 2011 12:37 pm
Arse - now it's at the garage it won't start
Post by BiggestNizzy » Thu May 05, 2011 2:11 pm
Update car push starts fine, the starter won't turn.
I thought I had fixed the problem by renewing the connectors at the battery end but no joy (it started fine yesterday.)
Post by Shug » Thu May 05, 2011 2:30 pm
It at GI Motorsport?
Elaine's just going there for an MOT
Post by BiggestNizzy » Thu May 05, 2011 2:36 pm
Nope Tarbolton
Post by BiggestNizzy » Fri May 06, 2011 4:53 pm
Does anyone know where I can get a pair of sidelight bulb holders ?
