Anti roll bar - 340R
Post by Gareth » Wed May 04, 2011 1:52 pm
My anti roll bar is making a horrendous creaking noise. Seems to be coming from the middle of the car. So I understand there's a rubber/nylon bush in the middle. Front undertray off and replace with this:
http://www.eliseparts.com/products/show ... ar-bushes/
Is that right?
TIA
G
Re: Anti roll bar - 340R
Post by tut » Wed May 04, 2011 1:57 pm
Those are the ones, easy job, but do not know if the 340R has a standard roll bar or stiffer one. Look at the ends, if they have four holes in they are the uprated ones, if plain they are standard.
Post by Gareth » Wed May 04, 2011 2:20 pm
Standard roll bar Tut.
Post by Gareth » Wed May 04, 2011 3:13 pm
Speaking rubbish. It's adjustable
roadboy
Post by roadboy » Wed May 04, 2011 3:56 pm
You don't need to replace the bushes Gareth. They just need greasing. Yours will have the nylon blocks rather than rubber bushes so easier to do.
HTH
Dan
SPS Automotive
Independent Lotus Specialists
Post by Gareth » Wed May 04, 2011 4:45 pm
Thanks Dan...I'll away and have a look....*removing undertray without a ramp...groan!*
Gourlay83
Post by Gourlay83 » Wed May 04, 2011 10:10 pm
roadboy wrote:You don't need to replace the bushes Gareth. They just need greasing. Yours will have the nylon blocks rather than rubber bushes so easier to do.
HTH
Dan
Also worth mentioning the nylon blocks are prone to crack, so worth checking while your there.
Alan
Post by Gareth » Thu May 05, 2011 8:56 am
Two undertray bolts spinning!
Argh!!!
Can't get them out.
Post by Gareth » Thu May 05, 2011 9:47 pm
What a nightmare.
Had to drill the pop rivets out of the undertray.
All done now and no more squeeking!
roadboy
Post by roadboy » Thu May 05, 2011 10:48 pm
Good stuff! :thumbsup
EDIT: Just got your voicemail. Did try to call you back earlier . Glad you got it sorted anyway. Sorry I didn't help. :?
SPS Automotive
Post by Gareth » Sat May 07, 2011 10:39 am
roadboy wrote:Good stuff! :thumbsup
No worries Dan. Didn't really expect you to answer in the evening.
4 hrs to get a undertray off. Rather frustrating!
Post by campbell » Mon May 09, 2011 11:40 pm
Look on the bright side Gareth, you can put them all back in fresh now and it will come off easier next time something breaks :-)
We've got some smart new fixings on UJI actually, using placcy fasteners where once there were bolts and rawlnuts (trailing edge of wheelarch liners...who thought up the rawlnut idea for in there eh :roll: )
Campbell
