I've had my first Elise for two days, a 2007 "S" — amazing car, but I need to (re)learn to be a lot more cautious in the wet than I had to be with my previous car!
Anyway, I would like to know whether some of the sounds I'm hearing while driving are 'standard features' or anything that could/should be investigated further. I would be most grateful for any input you can offer
- At low revs, the exhaust sounds a bit 'tinkly' to me... at first I thought it might be engine pinking, but I'm fairly certain it's exhaust-related. Has anyone else experienced this? I'm wondering if it might be a loose heat shield.
- First gear is a little whirry/whiny... nothing drastic, and it's 'underneath' the sound of the engine, but I wondered if that was normal?
- I hear a few rattles & creaks at low speeds over moderately uneven surfaces, but this seems less noticeable at higher speeds on the open road (perhaps because it's being drowned out by engine/road noise!). Hard to pinpoint the sources of the noises. I guess that this car and the other I test drove must've made similar creaks/rattles, or I would've noticed one making them and not the other... I was just wondering if they all did this, and where it tends to come from? I guess with less sound-proofing than a 'normal' car it should expected to an extent?
