Rev limiter LED fault
scottyf
Post by scottyf » Fri Aug 11, 2006 10:40 am
The LED for the rev limiter on my stack has started to flicker randomly!
Anyone else had a similar occurence?
MMC had a look and said its nothing to worry about but they will need the car in for diagnostics for a couple of days! :(
Manifold - Clothing for the Road & Track
http://www.manifoldonline.co.uk
ninja
Post by ninja » Fri Aug 11, 2006 11:09 am
sounds to me like a loose connection or a bit of water ingress perhaps
did it start when you washed the car or something silly like that?
ninja :drive
The_Rossatron
Post by The_Rossatron » Fri Aug 11, 2006 11:20 am
Probably the alarm playing up as it doubles as the security LED thing.
http://www.allflashnocash.com
scottyf
Post by scottyf » Fri Aug 11, 2006 11:22 am
Its been like that from the off!
Post by mac » Fri Aug 11, 2006 11:46 am
It's also the MIL lamp - so don't hang about too long.
Post by alicrozier » Fri Aug 11, 2006 12:15 pm
mac wrote:It's also the MIL lamp - so don't hang about too long.
Nope, MIL lamp is the nice orange one with a picture of an engine. :)
Is it flickering or just flashing regularly on and off (would suggest alarm).
Post by Shug » Fri Aug 11, 2006 12:16 pm
And how close is the rev needle to it when it flickers? :wink: :lol:
ninja
Post by ninja » Fri Aug 11, 2006 12:25 pm
i'm starting to think - alarm too as mine does this and my alarms silent anyway so it's kinda hard to know what's what
ninja :drive
scottyf
Post by scottyf » Fri Aug 11, 2006 12:32 pm
alicrozier wrote:Nope, MIL lamp is the nice orange one with a picture of an engine. :)
Was a very faint random flicker at the start, but seems to be more prominent now and seems to be agitated by bumps, so may well be just a loose connection (I hope).
Post by mac » Fri Aug 11, 2006 12:35 pm
Have they done away with the MIL lamp on the yota engine????
K series have the wee shift/alarm light in the middle of the rev counter as the MIL and also the engine check light (orange with pic of engine in it) too.
On the K the check engine only comes on if the cat is in danger.
Post by alicrozier » Fri Aug 11, 2006 12:42 pm
mac wrote:Have they done away with the MIL lamp on the yota engine????
I'd have to read the manual but mine has always lit the orange one. Solid light for MIL, flashing for terminal... :) (all IIRC).
Post by mac » Fri Aug 11, 2006 12:45 pm
Wonder why the changed it?????
I was able to diagnose Ninja's troubles as a misfire as that was the only fault that caused the "check engine" light to go on.
Was kinda handy having the two different systems - perhaps they only used the "check engine" as a throw back from the S1 111s misfire sensor.
Post by simon » Fri Aug 11, 2006 7:26 pm
I'll need to check my manual but I was always under the impression there was only 1 MIL light on mine and that was the one with the picture. The shift light is the alarm too but nothing else.
Post by mac » Fri Aug 11, 2006 8:13 pm
MY2001 Elise have the MIL lamp is also the shift & alarm light as detailed in the owners handbook. The service manual makes refference to the MIL and the engine check light (the one with the engine) as different failures illuminate different lights.
blackbird
rev limit led
Post by blackbird » Fri Aug 11, 2006 11:11 pm
the flashing rev limit led will be caused by water getting into the alarm ECU
it will need a new ECU
