Driveshaft oil seal
Tim S
Driveshaft oil seal
Post by Tim S » Sat Oct 01, 2011 3:35 pm
Here's an odd one - thoughts needed please!
About two months ago I changed (thanks largely to Robin's handy hints) a driveshaft gearbox oil seal (S2 111S - the nearside (short) one). All seemed fine and the car's done plenty of miles subsequently.
Then, this week, a puddle of gearbox oil appeared on the garage floor. I've just checked and it's clearly coming from the seal that I replaced - which seems to have failed quite suddenly as it's been fine for weeks but there's a fair amount dripped out now.
Any thoughts as to why this might have happened??
The real question is should I change it again or trust it to someone that really knows what they're doing!
Tim
roadboy
Re: Driveshaft oil seal
Post by roadboy » Sat Oct 01, 2011 5:46 pm
I'd be carefully checking the condition if the tripod joint going through the seal into the box.
Was it a genuine MG Rover seal?
Dan
SPS Automotive
Independent Lotus Specialists
Tim S
Post by Tim S » Mon Oct 03, 2011 5:03 pm
Thanks Dan. I got it from Geary so should be OK - looking at the website again though I see there are earlier and later types - may have orderred the wrong one though it looked the same as the one that came off.
Tim
roadboy
Post by roadboy » Mon Oct 03, 2011 7:57 pm
Easy to tell the difference. The early types are all black rubber to look at but the later types have a metal outer.
Dan
SPS Automotive
roadboy
Post by roadboy » Mon Oct 03, 2011 7:58 pm
Oh, and I've never seen an Elise with the early type shafts/seals.
Dan
SPS Automotive
Post by robin » Mon Oct 03, 2011 8:54 pm
I'm 99% sure that all S2 have the later type oil seal, no?
roadboy
Post by roadboy » Mon Oct 03, 2011 9:27 pm
I'm 99% sure that all Elises (S1 &S2) have the later type seal but yes, all S2s will use the later type. Definitely.
Dan
SPS Automotive
Post by Shug » Tue Oct 04, 2011 8:37 am
From memory, is it not reasonably easy to nip the seal if you're a bit brusque slotting the driveshaft in?
Post by alicrozier » Tue Oct 04, 2011 8:44 am
Yeah Shug, to the extent there is a special tool to protect it during refit IIRC...
Edited to add: I did RC. :)
http://www.deroure.com/search.asp?MAK=1 ... =T000T1390
Oh and early and late seal P/N's for S1 seals:
http://www.deroure.com/diagrams.asp?TBL ... 0&ST=&SC=0
Tim S
Post by Tim S » Tue Oct 04, 2011 1:07 pm
Thanks all
Yes, I did fit it without the tool - probably a mistake, though still odd it's been OK for so long before failing.
Anyhow, I've just chickened out of redoing it myself and have booked it into Ali's!
Tim
roadboy
Post by roadboy » Tue Oct 04, 2011 10:15 pm
I've never used the proper tool and I've fitted quite a few shafts. Its ok as long as you keep the joint totally square as you put it in.
Dan
SPS Automotive
