Elise S2 Battery
Jordan
Elise S2 Battery
Post by Jordan » Tue Nov 15, 2011 10:01 pm
I dont know if this is a silly question or not as im not that clued up on all the lotus bits and bobs yet... But ive just bought a charger for my 2001 S2 battery as its dead in the garage and on the instructions it says..
Check before you connect cables as some cars may have " positively earthed batteries " is this the case with the elise?
Charger bought is CTEK MXS 3.6
Lotus Evora , previous car history Elise S2 , Mini Cooper S
steviej
Re: Elise S2 Battery
Post by steviej » Tue Nov 15, 2011 11:52 pm
Elise is Negative earth, I have one of these terminals fitted, it saves disconnecting the battery totally when charging or not using the car for a long period, you just unscrew the knob, works as an anti theft device and would save the nightmare of reversed polarity connection, definately worth £5.
Battery Cut Off Terminal Switch Fits ALL Cars Bikes Boats ETC BS200 ABA103BXYZ
Post by robin » Wed Nov 16, 2011 9:27 am
Are you going to charge in situ or remove the battery? To be honest it's an easy job on S2 and so it might make sense to remove the battery and charge outside of the car.
If you're going to charge inside the car the +ve terminal is relatively easy to reach but the -ve terminal might be hard depending on the size of the crocodile clip on your charger; if you cannot reach the -ve terminal you can clip the -ve croc clip to the engine body instead (it's all earthed).
Post by alicrozier » Wed Nov 16, 2011 12:32 pm
I think charger should have a quick connect cable Robin (with terminals). So should be a one off job to fit this to the battery and run the cable outside the battery box into the boot...easy future charging...
Jordan
Post by Jordan » Wed Nov 16, 2011 10:17 pm
Cheers guys, i was just planning on keeping the battery in the car and connecting the charger to it that way as ive read about some of the problems that can happen when removing the battery and the way you connect it back it can fry the ECU unit which i dont want to even try doing...
im pretty sure il manage to connect the negative clip onto the battery easy enough without the need off removing the battery from the car
Karen
Post by Karen » Wed Nov 16, 2011 11:05 pm
Jordan wrote:Cheers guys, i was just planning on keeping the battery in the car and connecting the charger to it that way as ive read about some of the problems that can happen when removing the battery and the way you connect it back it can fry the ECU unit which i dont want to even try doing...
Or just watch out for the grey elise returning home and run across the street :thumbsup
Karen
JCW Mini Roadster
Jordan
Post by Jordan » Sat Nov 19, 2011 1:22 pm
Had my battery on charge for over 15hrs and still nothing... Derek thinks the battery could away
Im pretty sure this battery would replace the current one
http://www.halfords.com/webapp/wcs/stor ... 65762#dtab
whaleys
Post by whaleys » Mon Nov 21, 2011 11:24 am
Before you go spending too much on a Halfords battery, these guys are good, I've used them before. Their prices include VAT and delivery.
http://www.batterymegastore.co.uk/produ ... xide-rpt-/
http://www.batterymegastore.co.uk/produ ... uasa-rpt-/
Not used these guys before but they have cheap batteries, although its got lower cranking amps...
http://www.tayna.co.uk/063-Numax-Car-Battery-P937.html
Jordan
Post by Jordan » Mon Nov 21, 2011 7:45 pm
I got a halfords battery yesterday £77 but my friend has a trade card so with his discount i got it for £52 which wasnt too bad :) everythings working fine now, its off the road for winter now anyways so ill keep it on trickle charge through the winter.... :D
