Where in Central Scotland to fit an Emerald to an S2
Where in Central Scotland could i get an Emerald fitted with a decent map fitted to an s2, bearing in mind its alot harder to fit to an s2 than s1.
Falkland maybe? nd what sort of costs will we be looking at ?
Paul
Paul
- alicrozier
And I believe much harder to map on a VVC...tenkfeet wrote:Thanks .roadboy wrote:Not really on a standard engine. They are used when engines are modified beyond the capabilities of the standard ECU.
Dan@JPS
Not really, unless you're planning on farking about with the inlet cam timing. Dave Walker has a base map with the cam timing pretty much okay - after that, it's just fuelling & sparks like any other RR mapping session. If you want to get difficult and fiddle with cam timing, it will be much more difficult though (like juggling with 6 balls as opposed to 2 - you change cam timing and you've gotta re-map the fuelling & sparks before you see if it's helped)alicrozier wrote:And I believe much harder to map on a VVC...tenkfeet wrote:Thanks .roadboy wrote:Not really on a standard engine. They are used when engines are modified beyond the capabilities of the standard ECU.
Dan@JPS
- alicrozier
Yeh the car has been fitted with K05 head and 270 cams , and its rather lumpy at idle and jumpy at low revs.
Your Based in newcastle on Tyne is that Correct?
I havent got the Emerald yet but would either get one from DVA or Dave walker or yourself, depending wherer i could get a decent pre fitted Map that would be suitable for the car.
I take it we would need to bring the car to newcastle unless there is a quicker place to have it fitted?
Cheers Paul
Cheers Paul
