Rear brakes overheating.....
Post by DDtB » Tue Dec 27, 2011 7:18 pm
So I had a bit of squealing from time to time coming from the brakes on the Golf when driving along normally, so I put it into VW to see what was going on... mistakenly thinking they'd know about VW Brakes....
They told me my rear driver's side brakes were overheating and recommended new discs and pads. The current discs and pads are 11 months old. When I asked what the problem was and why new pads and discs would fix it, they couldn't give me any more info than that... they just kept telling me I didn't really 'need' new discs and pads, but as they were overheating it was the safe thing to do and 'should' fix whatever the problem is. They also said some of my other discs were dirty, so best to replace them and the pads too... :roll:
I asked if they'd checked the caliper and they told me it seemed fine.
I've just driven 30 miles and you can feel the heat from the rear wheel as you walk past so I'm not keen on leaving it too much longer.
Any suggestions for what may be the problem and how I could bodge it until getting it fixed properly !?!?!?
Cheers!
Dave.
Re: Rear brakes overheating.....
Post by Mike Scib » Tue Dec 27, 2011 7:47 pm
DDtB wrote:I've just driven 30 miles and you can feel the heat from the rear wheel as you walk past so I'm not keen on leaving it too much longer.
Just the one rear wheel i am guessing?
it will be a sticky caliper, try a good roosting firstly on the brakes to try and get it to work if that fails a new caliper will sort it.
fd
Post by fd » Tue Dec 27, 2011 7:51 pm
Most Likely a seized handbrake actuator in the caliper and or seized handbrake cable - they tend to go hand in hand as once one stops moving properly the other tends to seize up too. Release the handbrake actuator on the back of the caliper (rotate it away from the direction the cable would pull it - you should be able to reach this without removing the wheel or jacking up the car) then test drive the car WITHOUT using the handbrake - if it's cool then it's one of the above - once in the non overheating position it'll stay that way until you use the handbrake again . . . so just don't use the handbrake . . . if that doesn't fix it it may be the caliper piston itself seized or the sliding pins that the caliper moved on seized (very common but usually causes brakes not to work rather than to not not work ;-)) - no bodge to fix either of these issues, needs the caliper replaced or the sliding pins un seized - which can be a pain in the ar$e . . . helpfully the sliding pins don't usually come with replacement caliper kits . . . which can pose a problem . . .
Post by woody » Tue Dec 27, 2011 8:14 pm
SHED!!
Caliper most likely, see my recent experiences which amused you. ;)
Post by DDtB » Tue Dec 27, 2011 9:20 pm
Thanks for that .. Much appreciated :thumbsup
Will have a play around with it tomorrow lunchtime hopefully..
Hopefully it won't burst into flames on my commute first :shock:
Post by kenny » Thu Dec 29, 2011 12:59 am
Are the brake pads in the right way round?
Post by mwmackenzie » Thu Dec 29, 2011 11:28 am
is there enough water in it? :roll:
Post by tut » Thu Dec 29, 2011 2:08 pm
kenny wrote:Are the brake pads in the right way round?
Suffered that on a service once Kenny, even worse it was an MMC disk.
Post by alicrozier » Thu Dec 29, 2011 6:48 pm
I think he was inferring the OP has past form for the above... :lol:
Post by DDtB » Thu Dec 29, 2011 10:17 pm
I haven't touched the brakes on the Golf.... yet!
:finger
