S2 door locks
jimbo
S2 door locks
Post by jimbo » Fri Feb 10, 2012 3:39 pm
Did Lotus change the door locks between the S1 and S2 Elise? While killing time waiting at SLS I had a look around some S2's that were in, and noticed that all of them had a much smoother action. They sounded way less tinny and generally seemed much tighter. Are the doors that different??
James
Sent from my TITAN X310e using Board Express
S1 Elise 111s
Re: S2 door locks
Post by Shug » Fri Feb 10, 2012 3:45 pm
Locks are the same (Corsa boot lock) - more sound deadening in the doors the later you go. I notice no difference in the actual action between my S1 and Elaine's 111R
jimbo
RE: S2 door locks
Post by jimbo » Fri Feb 10, 2012 3:57 pm
Must be that then, plus I think that my doors have slightly dropped so maybe tightening up the alignment would help.
Cheers shug
S1 Elise 111s
Re: S2 door locks
Post by Shug » Fri Feb 10, 2012 4:21 pm
Yup - the S1 thunk when you push the button is the door falling off the pin ;) Mine's done that bit for years... Should sort it, but probably wont :)
