Brake pads...
Jordan
Brake pads...
Post by Jordan » Thu Mar 08, 2012 2:43 pm
I got new rear break pads fitted in december on my s2, it has been off the road since jan, i took it for a quick spin around the block the other day and when i breaked it sounded like the pads were rubbing on the discs and both front and rear pads have plenty life on them.... Anyone know what this could be ?
Lotus Evora , previous car history Elise S2 , Mini Cooper S
neil
Re: Brake pads...
Post by neil » Thu Mar 08, 2012 2:52 pm
It'll just be from lack of use. Give it a decent run and it'll be fine
Exige V6
scottishselise
Re: Brake pads...
Post by scottishselise » Thu Mar 08, 2012 3:08 pm
As neil says, it is most likely dirt/rust.
Re: Brake pads...
Post by tut » Thu Mar 08, 2012 3:09 pm
As Neil says, give it some rough love on a clear road, up to 60 and brake hard a few times.
Jordan
Re: Brake pads...
Post by Jordan » Thu Mar 08, 2012 10:57 pm
Thanks guys :)
Re: Brake pads...
Post by campbell » Thu Mar 08, 2012 11:54 pm
Where do you store your car, Jordan?
If garaged, then in the last half mile before home, especially if it's damp, do some (careful!) left foot braking to heat up the disks a little. This reduces the likelihood of corrosion binding the pads upon cooling.
Also park with handbrake off (assuming fairly level ground) with gear engaged.
If not garaged, there isn't much you can do other than get it out for a drive periodically. What a chore ;-)
Jordan
Re: Brake pads...
Post by Jordan » Sat Mar 10, 2012 8:06 am
campbell wrote:Where do you store your car, Jordan?
The car is kept in the garage :D i have it sitting in neutral and handbrake off.
Karen
Re: Brake pads...
Post by Karen » Sat Mar 10, 2012 10:18 pm
And if it should find itself out of the garage, then it's in our drive :-)
Karen
JCW Mini Roadster
