Ball Joints
mikeyb13
Ball Joints
Post by mikeyb13 » Mon Mar 26, 2012 11:24 pm
Got a front one to do. Imagine the first of many
Is the elise parts removal tool any good?
http://www.eliseparts.com/products/show ... oval-tool/
And where do the best ball joints? Any to avoid?
"I've had enough sh1t"
CubanGav
Re: Ball Joints
Post by CubanGav » Mon Mar 26, 2012 11:28 pm
The tool worked fine for me.
Don't buy any unless you are sure they are genuine Elise spec because they wont fit right. I'd probably just go for elise parts/shop ones to be safe.
Be prepared for the massive bang when they come off :)
jen
Girl racer
Re: Ball Joints
Post by jen » Mon Mar 26, 2012 11:43 pm
Hey Mike, if you've been trying to call Alan, his mobile isn't working so he can't answer when it rings. He also can't see who is calling cos the screen doesn't work. (and he slags iPhones off :roll: )
Avoid at all costs ones from Dingbro. They don't fit properly as it should be a straight thread and dingbros are tapered. We discovered this the hard way. I'm sure the ones we bought were from Eliseparts. :thumbsup
mikeyb13
Re: Ball Joints
Post by mikeyb13 » Mon Mar 26, 2012 11:54 pm
Thanks Gav. Yes Jen id txt him the other day but not about this. Will pm him.
Take it his hands a lot better judging by the amount of work he's done to the frog?
Re: Ball Joints
Post by woody » Tue Mar 27, 2012 12:07 am
jen wrote:Hey Mike, if you've been trying to call Alan, his mobile isn't working so he can't answer when it rings. He also can't see who is calling cos the screen doesn't work. (and he slags iPhones off :roll: )
Tapered thread? What was the brand? Just about to buy some, partco can only source me the one brand.
Re: Ball Joints
Post by robin » Tue Mar 27, 2012 7:44 am
You also get issues with some of them having a slightly increased OD of the main body which although you can press them in causes the ball to be pinched in the socket and the steering feels heavy if used at the front. Even Lotus had this issue and had to replace (or owners had to replace) the front four.
Unless in a rush it's worth just ordering them from Lotus or EliseParts/EliseShop where you hope they have vetted the parts to make sure they only get the good ones.
Gourlay83
Re: Ball Joints
Post by Gourlay83 » Tue Mar 27, 2012 8:11 am
Jen's half right, its the machined taper before the the thread. Some don't match the Lotus hubs, as I found out the hard way. The nut will tighten but it doesn't sit on the taper properly and moves around, and not easy to spot when you fit them.
I'm with Robin, buy from Elise parts. At least you know what you're getting.
mikeyb13
Re: Ball Joints
Post by mikeyb13 » Tue Mar 27, 2012 8:18 am
Cheers guys. Stu160's offered assistance so Im sure he will keep me right :thumbsup
foz01
Re: Ball Joints
Post by foz01 » Tue Mar 27, 2012 10:37 am
I still have your balljoint tool Alan, will drop it by of an evening now the lighter nights are coming in :)
Edited to say I could do with borrowing the EP tool as I couldn't get a standard one to work, and I need to relate about 3..
Motorsport K20 Elise
Re: Ball Joints
Post by campbell » Tue Mar 27, 2012 3:04 pm
The EP tool could use longer (and better strength) adjuster bolts, so I acquired some and that helps ease the process and makes it less "single use" too :-)
Welcome to borrow it Mikey, if you wish.
I also have a collection of balljoints, measured for front vs rear * and whilst you'd have to use them at your own risk, again you are welcome if you are in a hurry.
* - the correct ones are for the front, the slightly outsize (tight) ones are for the rear ;-) Thanks to Dan @ SPS for that tip, IIRC...
mikeyb13
Re: Ball Joints
Post by mikeyb13 » Tue Mar 27, 2012 4:14 pm
Thanks for the offer. Dont think theres any rush??
No plans any track action in the near future and it passed an mot 3 weeks ago.
I diidnt even notice it till Stu said he could feel it under load at Spa speeds.
Re: Ball Joints
Post by tut » Tue Mar 27, 2012 4:30 pm
I bought eight for N1 for a future re-fit, but they will now act as spares for N3.
Same with wishbone bushes, so at least they will not be wasted.
2F45T4U
Re: Ball Joints
Post by 2F45T4U » Fri Apr 06, 2012 12:02 pm
I bought the balljoint tool from Eliseparts a few months ago. I was disappointed by the build quality for the money. The female threads on the puller have been tapped at an angle off the square which made it a pig to get the bolts in when the puller was fully extended. I had to drill the clearence holes larger to make up for it. If i get another bit of plate i'll make a new one.
i would recommend it though. Saves having to take the wishbones off and sticking them in the press.
Re. balljoints, i cross referenced a part ages ago that was for a Chevette i think. part no: Delphi TC163. Its still fine after about 2k miles but i have started buying them from elise parts, normally to bulk an order up with consumables to make to the free postage.
if you're borrowing a puller from someone, id change a couple of balljoints in a oner. Once one goes the rest wont be far behind.
Re: Ball Joints
Post by Shug » Fri Apr 06, 2012 12:34 pm
Yup, tis a Chevette (or something equally prosaic) part number, but just ordering on those part numbers can, as others have said, get you parts with wildly varying tolerances - sometimes from the same supplier, supposedly in the same batch.
Really the only way to be sure is order through one of the Elise specialist sites these days - as has been said, these are sourced specifically for the Elise tolerances.
