Water in plug bores-update
vet111s
Post by vet111s » Sat Apr 14, 2012 10:03 am
Ok, so maybe first drive on Friday 13th wasn't such a hot idea especially after not driving it for 5 months.
With the aid of jump leads it was turning over really well and very nearly catching at times. No actual catch though.
So I checked for water in the plug bores and it's pretty wet in there. Is it simply a case of removing as much water as possible and liberal use of wd40 or is there something more complicated I'm going to need to do/use p&l for?
Tia
Ali
Stewart
Re: Water in plug bores
Post by Stewart » Sat Apr 14, 2012 10:33 am
Compressed airline, if available?
Stewart
vet111s
Re: Water in plug bores-update
Post by vet111s » Sun Apr 29, 2012 3:08 pm
Ok, frustrating update. Dried and cleaned bores as best I can (with a urinary catheter, 10ml syringe and can of compressed gas). New battery, just for good measure. All put back together and still no luck.
Fuel pump primes normally, engine turns over strongly but just won't catch. Occasionally sounds like it might catch but ultimately nothing.
Anything else a special needs home mechanic could try or best to get the AA on the case. (I have p&l)
Ali
kerryxeg
Post by kerryxeg » Sun Apr 29, 2012 11:08 pm
I'd try adding some fresh fuel, especially if it's looking low and has been sitting for some time.
Post by Rich H » Mon Apr 30, 2012 8:30 am
Check the dizzy leads, cap and rotor arm are intact and connected?
Post by BiggestNizzy » Mon Apr 30, 2012 8:43 am
Rich H wrote:Check the dizzy leads, cap and rotor arm are intact and connected?
I had a similar problem and found my distributor cap to be full of water and gunk replaced both the rotor and cap and it was all fixed
vet111s
Post by vet111s » Mon Apr 30, 2012 9:31 am
Am thinking along both of these lines, along with the coil packs possibly being knackered (there was a fair amount of rust on one of them when I pulled it to dry everything out). Going to get AA out this afternoon on the basis I could spend more money and a good bit more time and still be no further forward.
At least with p&l most of that expenditure will hopefully be recoupable.
Thanks, will keep you updated
Ali
Post by robin » Mon Apr 30, 2012 2:51 pm
If it's a 111S (going by user name) then it's got no distributor/rotor arm.
KingK_series
Post by KingK_series » Mon Apr 30, 2012 3:01 pm
robin wrote:If it's a 111S (going by user name) then it's got no distributor/rotor arm.
my thoughts, it is still likikely to be ignition, try new plugs and maybe new leads too,
vet111s
Post by vet111s » Mon Apr 30, 2012 3:14 pm
Aa out just now. No luck yet. Apparently the sparking is poor so far.
Post by Rich H » Mon Apr 30, 2012 3:25 pm
Doh. Not that then.
Poor sparks could be coil packs then, check the plugs to the coil packs are OK but they do die eventually.
KingK_series
Post by KingK_series » Mon Apr 30, 2012 4:13 pm
Doh. Not that then.
leads are a 12 months service item in my books. OEMs really deteriorate.
vet111s
Post by vet111s » Mon Apr 30, 2012 4:16 pm
Ok, so towing post broke trying to tow out of the drive. Managed to push on to road. Now awaiting low loader for a trip to MMC.
Thanks for all the input.
Have got p&l so hopefully this isn't going to hurt too much!
Ali
Post by Dominic » Mon Apr 30, 2012 4:37 pm
:( Hope your get it sorted without too much pain. At least you can be confident in MMC looking after it well :thumbsup
vet111s
Post by vet111s » Mon Apr 30, 2012 4:50 pm
Cheers Dom
Know MMC will look after it. Anxiety now is getting it on to the low loader using the wishbones.
