Tight gearbox 2009 exige
Dipper
Post by Dipper » Thu May 24, 2012 9:07 pm
My mates 2009, 8000mile exige has a really tight gbox. To the point that it's borderline dangerous. Running into a corner in neutral because you can't find 4th from 5th isn't clever. Rest of the ratios are pretty stiff and slow also. Comparing it back to back with a 2008 Elise sc, 12000miles. the Elises box is light and accurate.
At 8k Im assuming the box itself is fine. so anything we can take a look at before hiking 200odd miles to Murray's? Cables, Linkages possibly?
Re: Tight gearbox 2009 exige
Post by Shug » Fri May 25, 2012 9:00 am
Bleed the clutch first. That'd be my first port of call, then look at linkage adjustment etc.
Post by mckeann » Fri May 25, 2012 9:15 am
Walshy's 111R was being used on an activity day, and had a particularly hamfisted driver select 1st instead of 3rd, and managed to bend part of the linkage. If you have a spare car to check it against, that might work, otherwise Murrays know best
