Could someone with knowledge help fill in the gaps for me.
I've been trying to help a friend out, Mazda 323 failed MOT on rear brake efficiency. Basically handbrake wasn't doing much.
I adjusted the handbrake and got a marginal improvement.
Took out the pads cleaned and greased where they should move and greased and worked free the handbrake lever at the calliper.
One side now works fine, the other just barely works when the handbrake is applied. Both sides lok as though they have about the same movement and both now move freely when the brake is applied.
The footbrake works well both sides.
I'm thinking there is something wrong with the mechanism inside the calliper which should move when the handbrake is applied - correct? Probably caused by the handbrake spring sticking in one position on one side and the mechanism becoming stuck over time.
If so what next, is this repairable to a more experienced person or would you just fit a new calliper?
Any suggestions,
Kerry
Non lotus handbrake question
I would be inclined to find a scrappy and aquire a replacement, sounds like the internals are buggered. Prolly not worth a new part. Have a look at the caliper and see how it operated, give it a good clean and make sure the external bits move as they should. There will be a self adjusting mechanism in there this may have just got stuck. If you cna try and find a service manual, normally they hold the key to many an odd problem.
Good luck!
Good luck!
- thinfourth
