New flexi
New flexi
Would ptp be the cheapest place to get a new exhaust flexi? Mine has given up the ghost finally
http://www.ptp-ltd.co.uk/shop/340_36/lo ... _lotus.htm
James
Sent from my TITAN X310e using Board Express
James
S1 Elise 111s
Re: New flexi
Is it actually that part you need? That's not the standard flexi part. If you have the piper or janspeed 4:2:1 downpipe (standard only on sport 160 and VHPD engine'd cars) then you need this bit. If you have a standard downpipe (all other cars) then you need this part for S2:
http://www.ptp-ltd.co.uk/shop/26_32/lot ... nspeed.htm
And this part for S1:
http://www.ptp-ltd.co.uk/shop/25_30/lot ... nspeed.htm
I also don't think these are the cheapest prices for parts of that pattern - I seem to remember buying an MGF one for 99 quid, though it needed a bit of effort to make the rear hanger line up.
RE: New flexi
Yeah I have the Janspeed 4:2:1 off a 340R - another of Marks tasty pieces that found its way onto the 111s
So is that likely to be about the cheapest I'll find it?
S1 Elise 111s
Re: New flexi
It's probably the only place you'll get one if it's the janspeed part
Re: New flexi
If it's just the flex, you can buy another flex section and have it welded in. Depends if you know any good welders or not.
Re: New flexi
I would check with them that its priced correctly as I bought the same last year for the 340, from them, and from memory it was only around 60 ish?
Hairdresser at heart.
RE: New flexi
Ok cool, I'll give them a shout. Thanks guys
S1 Elise 111s
sjohnston777
Re: New flexi
Hi, I bought a new flexi direct from janspeed 2 month ago, delivered for £100.
Re: New flexi
That's a good price! Is that just the flexi section itself, or the pipe from the manifold to flexi, the flexi and the next bit of pipe?sjohnston777 wrote:Hi, I bought a new flexi direct from janspeed 2 month ago, delivered for £100.
sjohnston777
Re: New flexi
It was for the complete link pipe
Re: New flexi
It is a good price indeed! I remember paying near £300 for that part early last year,.. which is now beginning to have the flexi section come apart again
