wiring looms
wiring looms
Post by BiggestNizzy » Fri Aug 24, 2012 9:47 pm
I recently got myself some swish led rear lamps. And they come with a couple of mini looms that plug into the existing loom, its ugly and the plan is to make my own loom for the rear lights . I will use the existing connectors for the lamps and fit a 12 way dtm connector at the end of the existing loom so that I have a single connector for all the lights including reverse and fog.
The existing reverse and fog will go in the bin and I will remove that area of the rear clam for cooling .
Does anyone know where I can get the right cable and whatever it is that they cover it in so it looks professional ?
Re: wiring looms
Post by Mikie711 » Fri Aug 24, 2012 11:36 pm
Nizzy,
used Polevolt for loads of stuff in the past. They also have the DTM connectors as well as convoluted tube or PVC sheathing. One stop shop.
Re: wiring looms
Post by Rich H » Sat Aug 25, 2012 7:13 am
vehicle wiring products are old school and have pretty much everything you could ever need
http://www.vehicle-wiring-products.eu/V ... mepage.php
Re: wiring looms
Post by robin » Sat Aug 25, 2012 1:31 pm
Don't forget car builder solutions (google it).
Re: wiring looms
Post by BiggestNizzy » Mon Aug 27, 2012 10:59 am
Does anyone know how to work out what wattage my LED's run at ? I want to use the lightest cable (with a safety margin) and I need to know what wattage they run so I can work out the amperage on the cable .
I imagine all the elctrical people are laughing right now as I have probably used all the terms wrong.
but as I understand it
Amps = watts/voltage.(12)
Re: wiring looms
Post by robin » Mon Aug 27, 2012 11:45 am
For DC circuits power = amps * current.
You need to choose your cabling based on current it consumes, not the power in the LEDs.
A 48W headlight bulb would consume, at 12V, 4A and so you would go for 5A cabling, at a minimum.
I don't know what power your LEDs are - do you have a link or similar to show what they are?
Ta,
Re: wiring looms
Post by BiggestNizzy » Mon Aug 27, 2012 1:01 pm
http://www.eliseparts.com/products/show ... -lamps-s1/
The information I have from eliseparts is
Power Consumption (12V):
Stop 1.7W
Tail 1.0W
Indicator 1.5W
Reverse 3.2W
Fog 3.2W
Re: wiring looms
Post by robin » Mon Aug 27, 2012 1:16 pm
For example:
stop power = 1.7W
stop current = 1.7 / 12 = 0.141A.
As none of the above is more than 12W and given you won't find a cable rated for automotive use at less than 1A, you can just use 1A cable for each of them.
You could need to add them together if they're supplied on common lines - most likely one side of the LEDs is common in which case you need to use a wire big enough for all lamps for that wire - so 2xstop + 2xtail + fog + reverse + 2x indicator = 3.4 + 2.0 + 3.2 + 3.2 + 3.0 = 14.8W - so a 2A cable will be more than enough for any common wire and a 1A wire will be more than enough for any wire that's connected to just one LED.
ABZ-Elise
Re: wiring looms
Post by ABZ-Elise » Tue Aug 28, 2012 11:38 am
http://www.autosparks.co.uk/ just to throw another one in there. I bought a complete new wiring loom from them for my old Alfa. The quality was spot on.
1999 S1 Elise - For Sale
2003 E46 M3 - Sold
Re: wiring looms
Post by BiggestNizzy » Tue Aug 28, 2012 2:12 pm
Last night I pulled out the old loom, and pulled off the old reverse and fog lights my numberplate lights were looking a bit worse for wear so I have ordered a new pair of them, making my number plate more visable may not be the best move but I like things shiny.
I have ordered some nice 12 pin Deutsch DTM connectors to replace the rover 8 pin and 2 bayonnett fittings for the fog and reverse lights.
I am still pondering wither to replace all the cable with nice TE connectivity type 55A wire but that will depend on wither I can get it by the meter I am not spending £100 on a reel.
Tonights job will be to lay out the existing loom on a piece of cardboard marking up all my cable lengths and positions ready to start.
On another note the high brake light looks like it might be off some sort of SAAB
Re: wiring looms
Post by BiggestNizzy » Wed Aug 29, 2012 9:19 pm
My connectors arrived today deutsch dtm 12 pin. I have sourced some 0.5 dia wire that's rated to 6 amps so all being equal that leaves me a few amps safety margin on the earth cable.
I also started stripping down the original looms ( the eliseparts lamps come with slave looms) I am planning to use the existing connectors but that may change
Re: wiring looms
Post by campbell » Wed Aug 29, 2012 9:39 pm
That could come in handy. If SAAB hadn't collapsed a wee while back :-(
However, perhaps it's a stock GM part...
Re: wiring looms
Post by BiggestNizzy » Wed Aug 29, 2012 10:11 pm
My money would be on a Saab 900 from the early 90's
Edited to add should anyone search for this later on the high level brake light is from a GM SAAB 900 part number 4673257
Re: wiring looms
Post by campbell » Wed Aug 29, 2012 10:44 pm
pete
Vexatious Litigant
Re: wiring looms
Post by pete » Wed Aug 29, 2012 10:58 pm
Do you need some shrink wrap?
Text me colours and size and I'll have a word with our tels dept tomorrow...
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
