Losing tyre pressure
jimbo
Post by jimbo » Wed Nov 07, 2012 4:06 pm
Clark Motorsport noticed that my tyre pressures were seriously low, and I only checked them myself a couple of weeks back.
The rear was down EXTREMELY low :shock:
There was nothing wrong with the tyres, no nails or whatever stuck in them, so not sure why this would be. Answers on a postcard
Thanks
James
S1 Elise 111s
Re: Losing tyre pressure
Post by Dominic » Wed Nov 07, 2012 4:15 pm
Faulty valve? Leak in the wheel - crack somewhere?.. or bad seal from tyre to wheel.
Post by Rich H » Wed Nov 07, 2012 4:18 pm
Corrosion on the tyre sealing area?
jimbo
Post by jimbo » Wed Nov 07, 2012 4:34 pm
Anywhere in Aberdeen I can take it to have this checked?
S1 Elise 111s
Post by Shug » Wed Nov 07, 2012 4:40 pm
Most tyre places will have a big tub of water - fully inflate, push underwater and look for bubbles (obviously, wheel off car :)) Fairly foolproof method. Needs to be a really slow puncture not to show anything if you weight it and leave it there for 10 minutes while the kettle boils for a brew.
vet111s
Post by vet111s » Wed Nov 07, 2012 5:07 pm
Have heard of some alloys becoming porous over time. Might be difficult to pinpoint this though.
I'd agree, rule out obvious leak first.
Ali
Post by meatball » Wed Nov 07, 2012 5:49 pm
I agree with Rich...corrosion.
Post by j2 lot » Wed Nov 07, 2012 6:14 pm
+1.
We had the same problem with the winter hack & ended up getting wheels refurbished as its less hassle and risk than going to blow the tyres up every other day. Been spot on ever since.
N.B. if you listen to various experts you should be checking your tyres at leat once a week preferably daily :shock:
Post by Rag_It » Wed Nov 07, 2012 8:06 pm
Yeah Audi has the same problem, corroded alloys.
Car is going in next week to the Wheel Specialist in Dyce. www.thewheelspecialist.co.uk
Dave :thumbsup
r10crw
Post by r10crw » Wed Nov 07, 2012 8:09 pm
10% fairy and the rest water in your standard squirty mr muscle container and spray the wheel/tyre. You should be able to see even the the smallest leaks from the foamy bubbles.
Hairdresser at heart.
jimbo
RE: Losing tyre pressure
Post by jimbo » Wed Nov 07, 2012 11:18 pm
Cheers guys, will try that fairy test first, then potentially contact that wheel specialist (once I save some more pennies!)
Sent from my TITAN X310e using Board Express
S1 Elise 111s
cla5h
Post by cla5h » Wed Nov 07, 2012 11:27 pm
Just had to get one of the fronts on the Elise re-sealed as there was a slight leak from the inner edge due to corrosion (paint blistering and flaking off from that area.)
My bath was very dirty after I'd tracked down the spot it was leaking from - using a little soapy water outdoors wasn't revealing anything.
Post by Dominic » Thu Nov 08, 2012 10:38 am
RAMTOP_ERROR wrote:
My bath was very dirty after I'd tracked down the spot it was leaking from .
But your wheel & tyre were very clean! :thumbsup
Stevie
Post by Stevie » Tue Nov 13, 2012 10:00 pm
I run with ULTRASEAL (liquid tyre sealant) in my tyres. Have done for years. I would suggest given a try.
Post by Rag_It » Tue Nov 13, 2012 10:46 pm
The Wheel Specialist in ABZ has proved to be awesome.... Willie was fantastic, the missus picked up the car and they appear to have done an awesome job!!
