Harnesses.
pete
Vexatious Litigant
Harnesses.
Post by pete » Tue Apr 16, 2013 11:32 pm
After my last track day my back was sore so I going to try some harnesses. I've bought a bar (S/H) does anyone have any recommendations, there seem to be a wide range of prices.
I've standard seats and it'll be bolt in ones. Has anyone cut a hole in the seat base to fit a crotch strap (too much trouble?). I want to keep the seatbelts if possible cos harnesses are a pain on the road.
(And yes I've tried a CG lock and didn't find much benefit.)
Thanks for the help...
pete
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
Re: Harnesses.
Post by robin » Wed Apr 17, 2013 8:16 am
Eat more pies - cheaper and more fun :-) I've never liked wearing harnesses!
Why not ask Eliseparts whether they have a fitting guide for their harness kits - that way you'll know what's involved.
Although the crotch strap is hideous in all ways you can imagine, it will mean you don't extrude your liver through your mouth when you crash having not tightened the hip straps enough. 6-point probably slightly preferable if you're going to the effort of fitting these.
Were it me, I would probably remove the standard seat and fit something like this:
http://www.eliseparts.com/products/show ... iver-seat/
Or try to get an unwanted S2 Exige seat that has the harness holes in it.
Re: Harnesses.
Post by woody » Wed Apr 17, 2013 8:35 am
I've always been impressed with the Scroth harnesses Lotus fit. Good wide smooth webbing, easy to adjust with the tabs and they have an anti-submarine function which you may like. Not anti-submarine in a hardcore leftie Faslane protest kinda way, but in a patch in a shoulder strap that expands and stops the person slipping under the lap belts. Good solution to the crotch-strap issue.
Re: Harnesses.
Post by robin » Wed Apr 17, 2013 12:16 pm
Still only works if the lap belts are well enough adjusted - easy for a racing snake like Pete - not so easy for fat boyz like me - first you must find the hip bone!
Re: Harnesses.
Post by woody » Wed Apr 17, 2013 12:24 pm
robin wrote:Still only works if the lap belts are well enough adjusted - easy for a racing snake like Pete - not so easy for fat boyz like me - first you must find the hip bone!
Only an issue for Pete if he's planning an ambitious expansion programme then. :wink:
pete
Vexatious Litigant
Re: Harnesses.
Post by pete » Wed Apr 17, 2013 3:59 pm
That's excellent gents thanks. Hmm will think if I really need a new seat. I fancied a Tilett one but then i suspected I was just spending for the sake of it. And I can only afford one which will look stupid.
pete
PS I may have to change my name to "Racing Snake".
And get it written on the car.
And maybe on a specially comissioned hat.
'11 - '17 S2 135R
'23 - ?? Evora
graeme
Re: Harnesses.
Post by graeme » Wed Apr 17, 2013 4:03 pm
You could save money by shortening "Racing Snake" to "RS", pronounced "arse"? <BG>
211
958
philthy
Re: Harnesses.
Post by philthy » Wed Apr 17, 2013 4:44 pm
Saw these on ebay but realise you have already bought a bar.
http://www.ebay.co.uk/itm/LOTUS-ELISE-E ... 3cd0dc37cf
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
Re: Harnesses.
Post by tut » Wed Apr 17, 2013 6:13 pm
I fitted a used Corbeau Le Driver complete with harness the same as the one that Robin pointed to, after my back got worse, and the standard one was not giving me enough support, particularly on the track. CraigW fitted it the existing runners for me.
Added bonus was that it was higher and gave me a better vue.
pete
Vexatious Litigant
Re: Harnesses.
Post by pete » Wed Apr 17, 2013 9:32 pm
tut wrote:I fitted a used Corbeau Le Driver complete with harness the same as the one that Robin pointed to, after my back got worse, and the standard one was not giving me enough support, particularly on the track. CraigW fitted it the existing runners for me.
Cheersw tut, appreciate that (although I have the opposite problem from you - height is not something I need more of!)
'11 - '17 S2 135R
'23 - ?? Evora
pete
Vexatious Litigant
Re: Harnesses.
Post by pete » Thu Apr 18, 2013 12:13 am
graeme wrote:You could save money by shortening "Racing Snake" to "RS", pronounced "arse"? <BG>
Well you've spoiled my new name now.
I hope you're happy.
'11 - '17 S2 135R
'23 - ?? Evora
Re: Harnesses.
Post by robin » Thu Apr 18, 2013 1:30 pm
How about "Miserable Leftie Racing Snake" - is more catchierer I think.
Also it would set you aside from the other would-be Racing Snakes.
pete
Vexatious Litigant
Re: Harnesses.
Post by pete » Thu Apr 18, 2013 5:49 pm
robin wrote:How about "Miserable Leftie Racing Snake" - is more catchierer I think.
I refer you to the reply given in Arkell v. Pressdram (1971).
'11 - '17 S2 135R
'23 - ?? Evora
s29ttc
Re: Harnesses.
Post by s29ttc » Thu Apr 18, 2013 5:51 pm
I've got a set of mine if you want to see them, S1 though
1999 S1 Elise 111S - Fun Spec
Re: Harnesses.
Post by tut » Thu Apr 18, 2013 6:24 pm
Classic responce from Ian Hislop.
Here is my reply, "fcuk off"
