Steering Wheel Spacer + Sticky Stuff Removal
Wondering if anyone has used a steering wheel spacer with a standard S1 steering wheel. Find my knees getting in the road a touch when Im driving.
All I can see advertised is this for a snap on
http://www.elise-shop.com/steering-whee ... p-237.html
Also looking to replace the rear arch protectors, anyone got any tips for removing without damaging the paintwork.
"I've had enough sh1t"
Re: Steering Wheel Spacer + Sticky Stuff Removal
For the sticky stuff, you need some of this:
http://www.cleanyourcar.co.uk/index.php ... ductId=586
Incredible stuff
Incredible stuff
S1 111S
Cayman GTS
Prodrive Forester Turbo
Cayman GTS
- Scottish Scrutineer
I used that same spacer with 30mm M6 set cap-head set screws. Simple once the wheel is off.
Renny
Renny
Renny Thomson
MSA Scrutineer
Elise S2 (2002)
MSA Scrutineer
Elise S2 (2002)
A hair drier?mikeyb13 wrote:Also looking to replace the rear arch protectors, anyone got any tips for removing without damaging the paintwork.
Did you need to use any other parts to get the horn to work?Scottish Scrutineer wrote:I used that same spacer with 30mm M6 set cap-head set screws. Simple once the wheel is off.
Renny
No, there was enough slack in the wires. Simple crimp job if not.
Renny
Renny
Renny Thomson
MSA Scrutineer
Elise S2 (2002)
MSA Scrutineer
Elise S2 (2002)
