camchain
sendmyusername
camchain
Post by sendmyusername » Thu Jun 27, 2013 12:59 pm
Probably a silly question (that wont stop me) -
Camchains are not normally used as they sap power (minimally) and they are noisey (probably wouldn't hear it in the elise)
So instead of throwing timing belts at the engine constantly, how difficult/expensive is a one off cost of fitting a camchain ?
I'm assuming the cambelt is on the end of the engine and easy(ish) access, so just a few pullys needed.
I'm not planning on trying this anytime soon, but maybe in the future. Hoping to learn from other peoples mistakes (same principle of learning from your own mistakes, but much less costly)
If everyone else is 'thinking outside the box', thinking inside it means you are doing something different to the masses.
philthy
Re: camchain
Post by philthy » Thu Jun 27, 2013 1:05 pm
The costs invloved in new pulleys, chain and a system to keep it lubricated would far outway the benefits of changing the belt every service, especially if it is that easy to access.
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
Re: camchain
Post by woody » Thu Jun 27, 2013 1:46 pm
philthy wrote:The costs invloved in new pulleys, chain and a system to keep it lubricated would far outway the benefits of changing the belt every service, especially if it is that easy to access.
This. And a chain requires to be oiled. And you'd need to develop it to vbe better than an OEM belt in one go or it may result in the issue you seek to avoid.
Rosssco
Re: camchain
Post by Rosssco » Thu Jun 27, 2013 2:09 pm
As above... and a different tensioning system, plus cam chain are normally enclosed within the engine in some form to prevent corrosion and allow lubrication, where as belts are normally just covered.. You'd probably be easier fitting a different engine.
Plus timing chains wear out too. The NA VX220 engine uses a timing chain, and you can hear it in the cabin.
VX220 SC
M135i
Parajet V3 Moster 185
sendmyusername
Re: camchain
Post by sendmyusername » Thu Jun 27, 2013 6:02 pm
Cool, was just wondering.
All valid points I hadn't thought about, but pretty obvious really I suppose.
Re: other engine, is there nothing - newer + more reliable + more powerful + lighter - yet still torquey that's not the type R honda that fits in easyish ?
Before anyone asks - yes I am quite bored.
philthy
Re: camchain
Post by philthy » Thu Jun 27, 2013 6:26 pm
The duratec is a cam chain engine that's a another good option
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
GregorFuk
Re: camchain
Post by GregorFuk » Mon Jul 01, 2013 9:24 am
Indeed. You get a free Duratec with your camchain.
Not noisy btw, arguably quieter than a K.
Re: camchain
Post by BiggestNizzy » Mon Jul 01, 2013 10:06 am
Stick one of these in and be done with it.
Renault
Running costs however might be a little high
David
Re: camchain
Post by David » Mon Jul 01, 2013 11:37 am
GregorFuk wrote:Not noisy btw, arguably quieter than a K.
Try running it without oil pressure :shock: Great warning system :D
Caterham - R400
Mini Cooper
Duratec in Detail
flickr
Youtube
facebook
GregorFuk
Re: camchain
Post by GregorFuk » Tue Jul 02, 2013 8:20 am
I'll give that one a miss if it's all the same. Sounds expensive.
