Dyno
- flyingscot68
Dyno
I'd like to put the Evora on the dyno to see what it's putting out.
Any recommendations on who to use in the Glasgow area?
Cheers.
Cheers.
- douglasgdmw
Re: Dyno
Maybe not directly in Glasgow but when I had the Mitsubishi Evo VIII I went on a dyno day with the MLR at Extreme Motorsport in Whitburn (used them for my Evo servicing also).
http://www.extreme-motorsport.co.uk/dynocell.html
Maybe an option is no one else comes back with some Dyno locations in Glasgiw.
Thanks
George
Thanks
George
Alpine A110S
Mini JCW
Range Rover L322 4.4TDV8
Land Rover Series 2a softop
Mini JCW
- flyingscot68
Re: Dyno
Cheers George
Re: Dyno
I believe there is a decent place in Hillington. Never been myself though.
Re: Dyno
Yea Ecotune in hillington, http://www.ecotune-scotland.co.uk/contact a few friends have used them for remapping and dyno plots
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
- flyingscot68
Re: Dyno
Got it booked in there for next Friday.philthy wrote:Yea Ecotune in hillington, http://www.ecotune-scotland.co.uk/contact a few friends have used them for remapping and dyno plots
chris_c201
Re: Dyno
Look forward to seeing the results as think you've got same setup as me plus the radium..
Exige & Evora - Now gone
Porsche 911 (996) GT3
MK1 MX5
MK1 MX5
- flyingscot68
Dyno
I'll be there at three on Friday Chris if you want to pop along for a look.
chris_c201
Re: Dyno
Might try that, working next weekend again so might be a good excuse to make an early exit Friday...
MK1 MX5
MK1 MX5
- flyingscot68
Dyno
First run on the dyno showed 388bhp at the wheels.
I must have the most powerful N/A Evora ever built!
Something not quite right there.
- flyingscot68
Dyno
OK, so one full system reset later-
310.6 Bhp which I must admit is more than I expected.
The operator was adamant though that their dyno is known for reading less than some of the others around and that the figure is pretty accurate.
Wish I had a 'before' figure from when the de-cat and Radium weren't fitted.
At least it gives me a point to measure from if I go ahead with further tuning work.
Re: Dyno
Healthy - but usual caveats about it really only being a baseline on that day for you to check mods as you add them, etc... Which you know anyway
I've heard chatter about the exhaust system (and cats) being the real power limiter on the Evora, so makes sense if the cats are out that you'll see a jump.
Re: Dyno
The decat will only remove the third cat you need manifolds to get rid of the other 2.
- flyingscot68
Dyno
Not sure if I want to go that far as I believe it won't pass an mot like that.Mikie711 wrote:The decat will only remove the third cat you need manifolds to get rid of the other 2.
Plus we got stopped for a road side emissions test the other day.
A remap maybe, the guy at ecotune says it is running a little rich at present.
Decisions to be made
