ECUs...
ECUs...
Post by DDtB » Mon Jul 29, 2013 10:15 am
I'm currently running a standard ECU and looking at options...
There are a couple of 160 heads out there... And others with 160+. I'm assuming I can't run my standard ECU with them so wondering what options are out there.
Is emerald still the way to go... Or gems etc?!
Dave
Re: ECUs...
Post by Shug » Mon Jul 29, 2013 10:19 am
Emerald is the known quantity, IMO. Cheaper than other options with 99% of the functionality - and all the functionality you really need for a K series.
Re: ECUs...
Post by robin » Mon Jul 29, 2013 2:23 pm
With a fuel pressure regulator you'll be fine with the standard ECU up to 160 IMHO.
Agreed that if you must have an ECU then Emerald may well be the path of least resistance.
Post by DDtB » Mon Jul 29, 2013 2:28 pm
I'm guessing a 160 head plus go faster cams is definitely too much for the standard ECU then.
Just looking at options to get the car back running again... Nothing set in stone. Emeralds look pricey new so not sure it's worth the bother.
Re: ECUs...
Post by DDtB » Mon Jul 29, 2013 8:06 pm
This should also probably be in Technical so feel free to move it mods. Posted from my phone earlier and didn't realise I was in General Chat.. (that's my excuse and I'm sticking to it!)
Re: ECUs...
Post by robin » Mon Jul 29, 2013 8:40 pm
Done.
If it's a KR1 plus newman cams then I think Rog reckons it does OK on standard ECU plus a fuel pressure regulator, maybe with some restriction in the IACV air flow? Have you asked?
les
Re: ECUs...
Post by les » Mon Jul 29, 2013 10:23 pm
Rog's thoughts are that with a KR1, Newman Phase 2 cams, and 4-2-1 manifold/hiflo exhaust you are on the edge of what the MEMS 1.9 can handle. My engine (96 s1 1,6mpi) isn't properly timed yet but is on the hole handling all Rog's mods pretty well (after 1200 miles), its definitely overfueling and a little acceleration judder. I've signed up for the rolling road day at ecotune in September so I'll perhaps get a better idea about how well the engine is going then.
Re: ECUs...
Post by Mikie711 » Mon Jul 29, 2013 11:30 pm
With an Emerald you will be able to get a base map that will get you 80-90% of the way which will mean less RR time to set it up. Like Shug said compared to the rest much cheapness and perfect for the K.
Re: ECUs...
Post by campbell » Mon Jul 29, 2013 11:31 pm
What did the PTP 165 kit use?
Re: ECUs...
Post by robin » Tue Jul 30, 2013 8:39 am
Hi Campbell,
I think it went something like:
They started off supplying some sort of EFi ECU and in later revisions they moved towards "sort it out yourself, but we'll give you a map for an Emerald".
graeme
Re: ECUs...
Post by graeme » Tue Jul 30, 2013 9:25 am
DVA kits used an Emerald for anything over 155bhp, or 175bhp for the VVC.
In fact, the difference between the 155 and 160 kits seems to be the emerald and a bit more polishing, so DVA obviously feels 155 is around the limit of the standard ECU.
Re: ECUs...
Post by robin » Tue Jul 30, 2013 1:11 pm
Without adding a fuel pressure regulator I think 155 could be the limit of safe fuelling. The MEMS uses open loop fuelling on full throttle/above 4K - so it has no "learning/O2 sensor" input in this range. If you increase fuelling by upping the pressure a tad then it will be fuelled OK and it will use O2 feedback on cruise to dial back the fuelling to a normal level. It's not perfect, but you save the money on the ECU at the expense of ~100GBP on a FPR (avoid ebay specials - get it from somewhere like EP/QED/...).
Actually if you're really pikey you can squeeze the spring in the standard regulator to increase pressure, but this requires some expertise to get right so I have never tried it.
Fuelling is proportional-ish to fuel pressure; so let's say the MEMS on 3.0bar can do 150BHP safely, then increase the pressure by 10% to 3.3bar will fuel for 165BHP - ish.
les
Re: ECUs...
Post by les » Tue Jul 30, 2013 3:14 pm
Rob Bell on from the mgf register got a set of 10-15 FPR's manufactured to 3.3bar. He's sending me one up when he gets back from holiday as I wanted to keep the car looking more stock, and wasn't sure where the best place to install the FPR. Robin, so if I run an emerald with a wideband lambda, I don't need the FPR, is that the case?
Re: ECUs...
Post by DDtB » Tue Jul 30, 2013 9:40 pm
Thanks folks.. interesting reading.
Background here is that I have a standard head with Rog awaiting his KR1 magic, but he's struggling with so many people putting demands on him that I thought I'd see if there were other options out there that I could use as either a stop gap or permanent solution. Obviously it's impossible to have too much powerrrrrrrrrrr /clarkson.
Just thinking outside the box basically to see if there is an option I've not considered that might get my car back on the road a bit quicker, without sending Rog to an early grave with stress in the process!
Re: ECUs...
Post by Mikie711 » Tue Jul 30, 2013 9:46 pm
You will probably still need the FPR because at stock fuel pressure you will run out of injector duty cycle. You will likely have to bump the pressure to get enough fuel through the stock injectors. When I did mine I used 330cc injectors and these ran out of cycle at 3 bar, ended up with 440cc injectors running 3 bar.
