S1 engine troubles
jimbo
S1 engine troubles
Post by jimbo » Thu Sep 05, 2013 4:42 pm
I'm lost.
New plugs, new leads, brand new distributor, and still the engine under load is dropping to 2 cylinders with the emissions light blinking like crazy. Any ideas? It has never done this, ever, but can't seem to get it sorted now...
James
Sent from my GT-I8750 using Board Express
S1 Elise 111s
Re: S1 engine troubles
Post by Shug » Thu Sep 05, 2013 4:49 pm
Checked all the sensors? I had a bloody weird misfire when I had an HT lead too close to the crank sensor once, but if yours is on a dizzy, it's unlikely a lead would go that far astray. Sensor glitches can throw misfires though, so give them a check over.
Post by tut » Thu Sep 05, 2013 5:21 pm
James, bring it up to Old Deer and let Craig have a look at it, other than that the same with Ricky Gauld.
jimbo
RE: S1 engine troubles
Post by jimbo » Thu Sep 05, 2013 5:26 pm
Ok, I'll check it over and failing that I'll make a point of bringing it up Tut
James
S1 Elise 111s
Post by robin » Thu Sep 05, 2013 6:43 pm
Err, what actual car is this? Engine, ECU configuration? Ta, Robin
P.S. Because I cannot think of a distributor based K-series Lotus Elise that also had an engine check light that was wired to anything.
P.P.S. If it is not a distributor based car then chances are coil pack (it fails, takes 2 cylinders with it). If it is distributor based car, rotor arm is likely.
Post by tut » Thu Sep 05, 2013 7:18 pm
Tis Marks old car Robin. Not sure if that helps.
jimbo
Post by jimbo » Thu Sep 05, 2013 8:15 pm
Sorry my mistake, 111s with a split coil pack
S1 Elise 111s
Stu160
Re: RE: S1 engine troubles
Post by Stu160 » Thu Sep 05, 2013 8:41 pm
jimbo wrote:Sorry my mistake, 111s with a split coil pack
Change the coil pack, coild be the problem.
Stu
S1 S160
Caterham 310R
jimbo
Post by jimbo » Thu Sep 05, 2013 8:57 pm
Just have done, still the same issue
S1 Elise 111s
Stu160
Post by Stu160 » Thu Sep 05, 2013 9:22 pm
Ok.
Did it have the problem before you changed all the parts?
Dont know how it would have a distributor amd a twin coil pack??
Stu
S1 S160
Caterham 310R
jimbo
Post by jimbo » Thu Sep 05, 2013 9:58 pm
It doesn't have a distributor mate, that was me typing it by mistake. I only started changing the various parts because the problem started one day all of a sudden
S1 Elise 111s
Stu160
Post by Stu160 » Thu Sep 05, 2013 10:58 pm
Ok,so vvc engine, twin coil pack, and it is dropping to 2 cylinders only when under load?
Is it ok on start up, and doesnt misfire any other time?
Check the throttle position sensor connector, and also run through the reset for it, ignition on, slowly press the throttle pedel down 5 times, turn off ignition, wait 1 minute, then start the engine.( i think)
Stu
S1 S160
Caterham 310R
jimbo
Post by jimbo » Thu Sep 05, 2013 11:06 pm
Perfect on start up, no misfire at any other time. Will investigate further and get back to you...
S1 Elise 111s
Stu160
Post by Stu160 » Thu Sep 05, 2013 11:51 pm
When you say the light is flashing, which one is it, as i dont think they had one till the S2 with the twin lambda sensor?
S1 S160
Caterham 310R
s29ttc
Post by s29ttc » Fri Sep 06, 2013 2:07 am
It will likely be the misfire detection unit kicking in that is flashing the light
1999 S1 Elise 111S - Fun Spec
