Nitron C spanner
pete
Vexatious Litigant
Nitron C spanner
Post by pete » Thu Nov 07, 2013 6:39 am
Does anyone have one I could borrow?
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
Re: Nitron C spanner
Post by robin » Thu Nov 07, 2013 9:13 am
I think I do, but I also think it doesn't do anything useful :-) I seem to remember using two punches that were good fits into the holes and used them as a lever.
Post by woody » Thu Nov 07, 2013 9:22 am
I do. But as above, I've used the smooth end of drill bits in the past.
pete
Vexatious Litigant
Post by pete » Thu Nov 07, 2013 10:37 am
Thanks gentlemen (cancels TWENTY FIVE QUID order in other tab).
'11 - '17 S2 135R
'23 - ?? Evora
Post by Ferg » Thu Nov 07, 2013 10:37 am
Yes, the Nitron spanner is not very robust and bends and wear very quickly. I was disappointed that it was so poor when the rest of the product seems so good. Not tried the alternatives above but noted. :)
Post by mckeann » Thu Nov 07, 2013 11:45 am
I have one but from memory, there isn't enough room to use I when the dampers are fitted. You could remove a bolt to slide the damper out to give you more room, but those spacers are a barsteward to refit, so I'd stick with the 2 punches method.
pete
Vexatious Litigant
Post by pete » Thu Nov 07, 2013 12:52 pm
Spacers? The thing is already off sitting on my bench...
'11 - '17 S2 135R
'23 - ?? Evora
Post by robin » Thu Nov 07, 2013 2:26 pm
He hasn't got to the refitting part yet ... :-)
Post by mckeann » Thu Nov 07, 2013 2:43 pm
It's fine Pete, assuming you have 4 hands, a screwdriver and a hammer
Post by Ferg » Thu Nov 07, 2013 2:44 pm
The spacers are all the washers that fell to the ground when you pulled the shocks out. ;)
Post by Shug » Thu Nov 07, 2013 2:54 pm
The spacers are a piece of piss on the Nitrons, versus the squeeze, swear and hammer routine to try and get the rubber bushes on the original Konis to compress enough to let them in...
Post by robin » Thu Nov 07, 2013 4:14 pm
This is Pete we're talking about. Oh, and Mckeann's old car. Oh, and eliseparts brackets. I cannot see any problem there.
Post by Dominic » Thu Nov 07, 2013 7:30 pm
robin wrote:This is Pete we're talking about. Oh, and Mckeann's old car. Oh, and eliseparts brackets. I cannot see any problem there.
Post by woody » Thu Nov 07, 2013 7:35 pm
All is well with the Nitrons.
