Fitting a harness bar
pete
Vexatious Litigant
Post by pete » Tue Dec 03, 2013 1:39 pm
Does anyone know what size of bolts I need?
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
Re: Fitting a harness bar
Post by woody » Tue Dec 03, 2013 1:46 pm
pete wrote:Does anyone know what size of bolts I need?
To bolt what to what?
Post by Mikie711 » Tue Dec 03, 2013 1:49 pm
M10 x 75mm with flat washer.
TBA
Post by robin » Tue Dec 03, 2013 1:51 pm
Which bar are you fitting?
I think the left/right ends use the seat belt inertia reel belt mounting points, but presumably there are other bolts for the belts themselves. It should go without saying that you need the right bolt!!
The bolt is listed as "special".
Post by Mikie711 » Tue Dec 03, 2013 2:23 pm
The seat belts mount into captures that face into the car the standards bar fits into capture in the roll over hoop that are at the rear of the bar and below the seat belt mounts, just above the top of the speaker enclosures in a S1. The seat belts use a fine thread bolt and the bar uses a standard M10 bolts.
Fitting guide here
TBA
Post by Shug » Tue Dec 03, 2013 2:28 pm
Mikie711 wrote:The seat belts mount into captures that face into the car the standards bar fits into capture in the roll over hoop that are at the rear of the bar and below the seat belt mounts, just above the top of the speaker enclosures in a S1. The seat belts use a fine thread bolt and the bar uses a standard M10 bolts.
Fitting guide here
Pete's got an S2 - wasn't aware they'd kept the captive nuts for the harness bar.
Post by Mikie711 » Tue Dec 03, 2013 2:45 pm
They are both the same but the bolt for the S2 in shorter at 30mm. The mounts are in the same place but it's a bigger job to fit in an S2 if it has the rear plastic panel which will need cut to suit.
TBA
pete
Vexatious Litigant
Post by pete » Tue Dec 03, 2013 2:46 pm
Fitting guide here
That's spot on the captured nuts are there just need bolts. I think the bar is an eliseparts one I got it secondhand.
Seats are out as is the trim.
'11 - '17 S2 135R
'23 - ?? Evora
Post by tut » Tue Dec 03, 2013 4:24 pm
Going racing pete?
pete
Vexatious Litigant
Post by pete » Tue Dec 03, 2013 4:33 pm
Getting old tut. Last track day I do did my back was my limiting factor from being thrown around. Even at the sedate speed I travel at!
'11 - '17 S2 135R
'23 - ?? Evora
Post by mckeann » Tue Dec 03, 2013 6:32 pm
harnesses are sh*t, get a CG lock
Kinger
Post by Kinger » Tue Dec 03, 2013 7:07 pm
I seem to recall my 1st Kit car failed its SVA test as I have fitted Grade 8.8 bolts, it had to be High tensile 10.9 bolts to meet the Regulations at the time.
Worth the extra few pence since your life might depend on them one day ( Hopefully not)
pete
Vexatious Litigant
Post by pete » Tue Dec 03, 2013 7:10 pm
The marvellous Mr Nizzy has delivered just such items.
I have a CG Lock, I just don't get on with them.
'11 - '17 S2 135R
'23 - ?? Evora
pete
Vexatious Litigant
Post by pete » Tue Dec 03, 2013 7:49 pm
mckeann wrote:harnesses are sh*t, get a CG lock
Found a pair of sunglasses under the passenger seat. Calvin Klein, bit scratched, would suit an oddly shaped head. Yours I presume.
'11 - '17 S2 135R
'23 - ?? Evora
Post by mckeann » Tue Dec 03, 2013 10:37 pm
i lost those bad boys on the last ever frolic i did. Cant remember what year that was.
