Fitting harnesses
pete
Vexatious Litigant
Fitting harnesses
Post by pete » Thu Mar 27, 2014 9:39 pm
I know someone have managed to leave the seatbelts in (Shug) do you need to retain the spring that on the bolt that holds teh setbelt socket to the seat? There's not really room for that and the harness strap and the socket itself.
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
Re: Fitting harnesses
Post by Dominic » Thu Mar 27, 2014 10:11 pm
I have both types is seatbelts / harnesses in my car. Fairly sure there are no springs involved in the fitting of them. :thumbsup
pete
Vexatious Litigant
Post by pete » Thu Mar 27, 2014 10:32 pm
Dominic wrote:I have both types is seatbelts / harnesses in my car. Fairly sure there are no springs involved in the fitting of them. :thumbsup
Cheers dude.
'11 - '17 S2 135R
'23 - ?? Evora
s29ttc
Post by s29ttc » Thu Mar 27, 2014 10:36 pm
I have both too, I can't remember if there is a spring, from memory it was washers only but it was about 4 years ago. Cars up at Murray's or I'd have a look
1999 S1 Elise 111S - Fun Spec
Post by Shug » Thu Mar 27, 2014 11:51 pm
I didn't leave the seatbelts in. So no idea ;-)
Sent from my C6903 using Tapatalk
Post by BiggestNizzy » Fri Mar 28, 2014 8:55 am
The spring is there to stop them rattling about when nobody is sitting in the seat.
pete
Vexatious Litigant
Post by pete » Fri Mar 28, 2014 10:43 am
I mean what I should do si go out to the garage and bolt the bloody things in rather than sitting on the internet.
That's still true.
'11 - '17 S2 135R
'23 - ?? Evora
Post by Ferg » Sat Mar 29, 2014 1:37 pm
When I was considering the same thing, there was a special kit required to allow you to keep both. That MSAR place did them. :-) They are a helpful bunch too.
istoo
Post by istoo » Wed Apr 23, 2014 4:17 pm
total newbie question, how does that work, can you send me a photo. I quite want harnesses in mine
S2 111s
s29ttc
Post by s29ttc » Wed Apr 23, 2014 4:41 pm
Basically leave the seatbelt in. At the side of the seat one end has the seatbelt plug and the other the bottom strap of the seat belt. This is the same area where each waist part of the harness fits. I think the questions raised where how best to mount both either with a spring separating each part or washers. The shoulder parts then fit to a bar that's fitted behind the seats.
