The Elise has developed a bit of a knocking noise.
It's more noticeable at slow speeds and stops when the brakes are applied.
My thoughts are something to do with the brakes
Rear disks and were replaced and pads all round at the beginning of March. Also had both front lower balljoints replaced.
Anyone got any ideas what I should be looking for?
Knock, Knock
- duggiesmith
Knock, Knock
Duggie
Aubergine Elise S
Plum Crazy Exige 410 Sport
Aubergine Elise S
Re: Knock, Knock
Who's there?
Re: Knock, Knock
Pad retaining springs are probably upside down or you need buffers for the pads
- duggiesmith
Re: Knock, Knock
Cheers Stephen (and Tut
Next question - would this be something I should be able to sort myself (no technical skills) or should I leave it to the professionals?
Duggie
Aubergine Elise S
Aubergine Elise S
Re: Knock, Knock
Easy peasy
The retaining springs are on the front and should push the pads up. If they are pushing the pads down remove the pins and turn them round.
If that doesn't fix it stick some buffer pads on the callipers.
Have a look here under noises.
http://elise-faq.info/index.php?title=Brakes
Re: Knock, Knock
The other thing to check is make sure the top bolt on the rest calliper hasn't worked lose.
Re: Knock, Knock
I'm sure Woody means rear. It's wine o'clock on a Sat after all
