Accumate charger not charging
smee
Post by smee » Sun May 04, 2014 8:25 pm
Car wouldn't start today despite being plugged into accumate charger since it was last out. I had noticed the light hadn't turned green, the power light was on but not the charging light. I tried it with the fitted plug (bolted to the battery terminals) and with the crop clips. The inline fuse is also ok. Is the charger nadgered or is it a problem with the battery? After using jump leads to start the car it was fine for the rest of the day.
Thanks
S1 Elise - LRG MMC
Exige 390 LRG
GR Yaris
Leighton T6.1
Re: Accumate charger not charging
Post by Ferg » Sun May 04, 2014 10:17 pm
Try it on another battery before deciding it's the charger. :-) If it is the charger then maybe the wires between the unit and where it connects to the fly lead is broken in some way?
Post by Sanjøy » Sun May 04, 2014 10:27 pm
Have you been drinking this weekend? Sure they were on the right terminals?!
smee
Post by smee » Sun May 04, 2014 11:21 pm
Will try on another battery.
On the right terminals sanjoy, the port had been wired into the terminals for a year or two
S1 Elise - LRG MMC
Exige 390 LRG
GR Yaris
Leighton T6.1
Post by DDtB » Mon May 05, 2014 12:36 pm
Check the metal pins inside the white connectors too.
One of mine broke a year or two back and I didn't notice. New connector cable and it's fine again.
neil
Post by neil » Fri May 09, 2014 3:04 pm
I've got a spare accumate you can have if yours is goosed
Exige V6
dlogan
Post by dlogan » Sat May 10, 2014 9:53 am
Just a thought but I was advised that my accurate was a conditioner/top up only and won't recover a flat or discharged battery, it's just not got the oomph.
Try charging the battery back up on a run and then plugging in the accumate and see if it works.
Apologies if that's been tried already.
Post by Ferg » Sat May 10, 2014 12:16 pm
I looked into that recently when I had a flat battery. While it won't do it fast an accumate will recover a flat battey. I didn't beleive it but it does say so in the instructions, takes a few days though. So getting an initial charge into the battery with a conventional charger is more appropriate and significantly faster. :)
Post by campbell » Sat May 10, 2014 12:25 pm
My Halfords poverty spec charger has recovered the Elise batteries from the dead a number of times, as well as the Skoda once too :-)
