Engine mouting woes
jimbo
Engine mouting woes
Post by jimbo » Tue May 20, 2014 5:15 pm
Got a call from JD motors just now, engine mounts haven't actually gone it appears, but it's difficult to describe what actually has. He said that on the timing belt side, there is a bracket/alloy housing/flange that secures the mount to the actual block itself, which is secured with 2 M14/M16 bolts. These bolts are what have sheared (which he's never seen) and there is no way of getting them out, so I need to get a replacement bracket/housing/flange and the bolts.
Does this make sense to anyone, who can point me in the right direction of replacements? I need to get them ASAP :?
S1 Elise 111s
jimbo
Re: Engine mouting woes
Post by jimbo » Tue May 20, 2014 5:17 pm
He also said that he thinks later Elises with the K series had the bracket replaced with a 3 bolt style one, rather than the older 2 bolt one that I have, though wasn't entirely sure
S1 Elise 111s
Post by robin » Tue May 20, 2014 6:47 pm
Every one I have seen has a two bolt bracket with the big bolts being 18mm spanner size.
They shear when people don't tighten them properly :-( Once one goes, the other soon follows (twice the load, I guess).
I have some sitting up in Old Deer area but won't be able to access them until the weekend. If you can wait until then I'll strip them off and drop them with you on Saturday as I'll be up anyway.
Failing that I have another set down here in Edinburgh that you could have but you would have to wait for the post ... and I would have to find them ... as it happens I'll be in the garage tonight so I'll have a wee peek to see if they are where they should be; if not, I'll probably not find them until I no longer need them :-)
Will post an update later tonight.
jimbo
Post by jimbo » Tue May 20, 2014 7:11 pm
Hi Robin, if you can find them down there then perfect. Do you have the bracket as well? I need that too. I'm more than happy to pay you for them, and pay for special delivery to JD Motors directly.
Let me know, cheers
S1 Elise 111s
Post by robin » Tue May 20, 2014 10:17 pm
Hi Jimbo,
50% success - I have the bracket but not the long M14 bolts that connect the bracket to the chassis side mount. These are:
A111E6008F Bolt, M14 x 2 x 80
Obviously there are 2 of these.
In the short term you could use any M14 x 2 x 80 bolt with a washer (the proper bolt have the sort of head that has a "washer" built in) while you order up the real one. If you swap them one at a time the joint doesn't go loose so it's really easy to change - just need to remove the rear wheel and wheel arch liner.
In the longer term I would suggest ordering new bolts (they are about 4 quid from Lotus - probably £1 anywhere else :-)). I'll check with MMC if they happen to have any (unlikely) as I will most likely be there tomorrow.
Meanwhile if you send me the address of JD motors I'll send the bracket special delivery so they should receive it by 13:00 on Thursday. I have to go to the post office to get car tax anyway.
jimbo
Post by jimbo » Tue May 20, 2014 10:42 pm
Hi Robin, you're a legend. I sent Craig at MMC an email tonight about the same so fingers crossed he has some, failing that I'll get him to order them up for me.
Address for JD is
JD Motor Engineers
Unit 2, South Road Industrial Estate
Insch AB52 6XF
Proprietors: Dave Sedgwick and John Bruce
send me your PayPal details and the costs for the bracket and postage mate, thanks again :thumbsup
S1 Elise 111s
jimbo
Post by jimbo » Tue May 20, 2014 10:55 pm
Just looking at Deroure just now, is it part 2 the engine upper mount bracket, to go with part 11 the 2 m14 bolts?
http://deroure.com/diagrams.asp?MAK=1&M ... 0&ST=&SC=0
S1 Elise 111s
Post by robin » Wed May 21, 2014 7:42 am
No, item 2 is part of the chassis-side mount - I don't have one of those and I doubt that's the part you've broken.
I have the engine side mount, which is the part that contains the threads that receive items 11 and presumably the part that was damaged when the bolts snapped?
Note: as far as I can see the engine side mount is not shown anywhere on the parts diagrams.
Post by robin » Wed May 21, 2014 7:44 am
I'll get the part sent today anyway - if it's not the part they need, they'll know tomorrow. I may or may not have the other side up North ... I would need to take a look to find out, which won't be until Saturday morning.
jimbo
Post by jimbo » Wed May 21, 2014 7:58 am
Ok thanks Robin
S1 Elise 111s
Stu160
Post by Stu160 » Wed May 21, 2014 9:38 am
I know i will have them in my garage, but i am away till sunday night.
If you are still needing them then, i will look them out for you.
Stu
S1 S160
Caterham 310R
jimbo
Post by jimbo » Thu May 22, 2014 8:17 am
Hi Stu, thanks man I'll keep you posted if it's not the right one. Cheers
S1 Elise 111s
jimbo
Post by jimbo » Thu May 22, 2014 2:19 pm
Hi Robin, bracket arrived today and it's the correct one. Thanks very much :cheers
S1 Elise 111s
Post by robin » Thu May 22, 2014 3:23 pm
Good, Craig mentioned that he's getting the bolts - are you going to wait for those or just use some others? I would recommend new bolts of correct type for longevity if at all possible.
jimbo
Post by jimbo » Thu May 22, 2014 3:26 pm
Yeah bolts arrived with Craig today so he's just sent them on for me :D
S1 Elise 111s
