Sorry if this has been asked before...
I need to do all these rear end jobs before the car goes back on the road. I read recently that the cam belt interval time-wise means its now due (the car has been laid up for 5 years in my garage!) So my list of jobs would be as follows:
Cam belt and tensioner replacement
May as well do the alternator belt when I'm there
And suppose I may as well do the water pump as its almost off by this stage
Probably should replace the gearbox oil with good synthetic stuff
Need to replace the broken flexi exhaust pipe
Need to replace the rear section of the handbrake cable as I had to cut the old one to release the handbrake off the rear discs
Will also be changing the oil/oil filter, air filter, fuel filter and spark plugs.
So with all this to do would it make sense to remove the read clam or is this still all more than possible with rear clam in place? The last thing I need is more work. But the front clam is off at the moment since its at the bodyshop getting painted.
The rear diffuser and under tray are already off so I can get access to replace the flexi pipe and handbrake cable. The brake disks and calipers are already off as they are being refurbished by people more able to do that sort of stuff.
So before I start dismantling any more I'd like to know if its a no brainer or not.
Many thanks
