Ball joint
Ball joint
Yep, today it's lower ball joint time!!
So do I go for a Elise parts one or order a genuine one from them?
Mike.
Mike.
(that's why I think Mike will do fine, that and his lack of imagination).![]()
Re: Ball joint
Mike Scib wrote:Yep, today it's lower ball joint time!!
Mike.
Mine are all EP to EP spec.
I did try the pikey Partco route for 2 a long time ago but didn't even get as far as fitting them. The EP ones seem to be pretty good.
Re: Ball joint
So the £20 one woody?
Anyone got the tool I can borrow?
Re: Ball joint
Mike Scib wrote:So the £20 one woody?
Yes and yes.
Re: Ball joint
Doh! Ordered the tool plus a spare ball joint! Went for the £20 ones.
Plan on doing all the bushes, ball joints over the winter so sure I will get my money's worth out of the tool!
Re: Ball joint
You might need to source some better threaded rods and/or lube well before use - the threads can look pretty tired pretty quickly!
Also I would avoid the ball joints from motor factors for the Elise (in general I am sure they are OK) - there seems to be some confusion about the correct diameter and so you get ones that just won't fit.
Re: Ball joint
The ones I had had the wrong thread too.robin wrote:You might need to source some better threaded rods and/or lube well before use - the threads can look pretty tired pretty quickly!
As for the tool, the one I have had had another set of holes drilled & tapped and is on the third set of bolts.
For the bushes, I found a threaded bar, 2 sockets and 2 nuts on the threaded bar to be ideal. Much better than the sockets & G clamp I initially used. Will be doing the rest bushes soon having done the fronts a few k ago.
Re: Ball joint
Did you use genuine bushes Woody, not sure I am keen on the Power Flex ones or the Ertacetal bushes Elise Parts sell.
Re: Ball joint
I use the original rubber bushes from Lotus now and won't use anything else. Having tried at one point or other about every kind including nitron spherical bushes I think the originals have the best feel and durability compared to everything else.
BMW M2 Comp
BMW R1300GS
BMW M2 Comp
BMW R1300GS
Re: Ball joint
£350 just for the bushes! Soon adds up once you add ball joints plus refurbing the wishbones!
Re: Ball joint
I used, and will use, these:
http://www.seriouslylotus.com/suspensio ... e-bush-kit
They are supposed to be equivalent to and certainly look the same as, the lotus OEM bushes. Read somewhere a while ago it's the supplier but to a slightly stiffer spec as they can't supply the exact lotus spec.
ETA, I'd never used nylatron or poly type bushes. The spherical bearing type is a bit of overkill for me too.
Re: Ball joint
Looks like the kit I will be wanting!
http://www.seriouslylotus.com/suspensio ... efresh-kit
Thoughts?
Thoughts?
Re: Ball joint
Yep, not cheap to do but then you don't do it very often so worth buying the best IMHO.Mike Scib wrote:£350 just for the bushes! Soon adds up once you add ball joints plus refurbing the wishbones!
BMW M2 Comp
BMW R1300GS
BMW M2 Comp
BMW R1300GS
Re: Ball joint
I use QH ball joints. Delphi should also be fine. There was a batch of QH ball joints that were wrongly boxed a while ago which took a while to be flushed out of the system.
Re: Ball joint
Delphi have a part number specifically for the Elise now. Pretty sure this is what all the Elise specific suppliers sell as their own. I always use delphi ones and have never had an issue.
I just ordered two of those Seriously Lotus refresh kits. Great value for money!
Dan
Dan
