Indicators not working - but hazards do!
StiflerMR2
Post by StiflerMR2 » Fri Dec 19, 2014 5:19 pm
As per title, went to indicate to swap lanes on the motorway and got nothing, no light on the dash, no clicking no clicking nothing :?
Got home and played around with the hazards, which do work oddly enough. Could it be the stalk itself has just given up the ghost?
If it helps the battery was disconnected today....I can't help but feel that might have something to do with it.
Will check the fuses tomorrow as it's too dark now but thought it was worth checking if this is a TADTS ;)
Re: Indicators not working - but hazards do!
Post by robin » Fri Dec 19, 2014 9:22 pm
Fuse 6 is your friend (should be 7.5A) - same on both early and late S1.
StiflerMR2
Post by StiflerMR2 » Fri Dec 19, 2014 10:15 pm
Thanks Robin - will check tomorrow morning :)
ETA: fuses all looked good so jabbed the hazards off and on a few times and now the indicators work :?: :thumbsup
roadboy
Post by roadboy » Sat Dec 20, 2014 10:27 pm
Yup, dodgy hazard switch. Indicator power runs through the switch. Will need replacing at some point.
Dan
SPS Automotive
Independent Lotus Specialists
StiflerMR2
Post by StiflerMR2 » Sun Dec 21, 2014 9:24 am
Thanks Dan, my car is getting to be very much like Triggers broom ;)
Post by Ferg » Mon Dec 22, 2014 2:47 pm
Great description of an S1! :thumbsup
Post by woody » Mon Dec 22, 2014 2:55 pm
Had the same issue this year, ebay pug 205 switch (like new) cured.
Also installed a new fog light switch at the same time which cured a rear light that wouldn't light up and side lights that were sometimes on sometimes off.
StiflerMR2
Post by StiflerMR2 » Mon Dec 22, 2014 4:17 pm
Funnily enough woody my dipped beam switch also turns on my rear fog light :)
Another part to put on the order list I guess :)
2F45T4U
Post by 2F45T4U » Mon Jan 05, 2015 10:43 pm
You can ebay early Pug 106 and 205 switches. Ive just replaced my hazard switch which cured the issue you have.
Cheap cheap. Once you have a good one you can disassemble the old one and fix it.
Post by Stephen » Tue Jan 06, 2015 8:12 am
The 306 also had the same switch units I think.
StiflerMR2
Post by StiflerMR2 » Tue Jan 06, 2015 8:50 am
Thanks for the info guys, will take a look :thumbsup
Post by Corranga » Tue Jan 06, 2015 9:54 am
You can also get a matching heated rear window switch which you can use for the heated seats that you have.
Except that despite having your seats re-trimmed, and having the heated elements fitted years ago, you never actually get around to wiring them up :leave
