Tyres - A048 content
Measured my tyres and I've got between 2 and 3mm left on the left rear, a little more on the right rear. I plan on using them on Saturday at KH so should I order another set from Wheels Around to fit after?
An alternative I thought of would be getting Wheels Around to swap the right and left tyres over, the 48s aren't side specific are they? Not sure if they could do that on Saturday without a proper lift jack though.
Re: Tyres - A048 content
Just order a pair... They will be goosed, unless you're still mr slowasssimon wrote:Measured my tyres and I've got between 2 and 3mm left on the left rear, a little more on the right rear. I plan on using them on Saturday at KH so should I order another set from Wheels Around to fit after?
Depends how much your going to use it Si but you'll probably still be legal after the track day so its convienence. Do you have a second set of winter wheels?simon wrote:Measured my tyres and I've got between 2 and 3mm left on the left rear, a little more on the right rear. I plan on using them on Saturday at KH so should I order another set from Wheels Around to fit after?
If it helps soothe you, I'm running LTS spec rear 038s and SS fronts....simon wrote:Ronnie has put my name down for a pair of rears but he didn't know what they'd manage to get in time for Saturday. He said he'd try and get MH but it could end up being M instead, anyone know if there's a big difference?
Not dead yet
