Not liking the sound of this rattle
Post by kenny » Sun Oct 08, 2006 8:43 pm
I seem to have developed a worrying rattle, sounds like its coming from the gearbox although not 100% sure. Car is working fine, could just be something loose but it does sound a mechanical rattle, usually only happens once the car is warmed up.
Any ideas as to what it might be and where I am best to take it to get looked at.
Post by Dominic » Sun Oct 08, 2006 8:54 pm
IMVHO: Heat shield? :?
Post by Rich H » Sun Oct 08, 2006 9:08 pm
Fill gearbox with oil.
Helps loads :wink:
Seriously though changing the gearbox oil did wonders for my washing-machine-full-of-nails rattle if it's the 'box.
Re: Not liking the sound of this rattle
Post by robin » Sun Oct 08, 2006 9:17 pm
kenny wrote:I seem to have developed a worrying rattle, sounds like its coming from the gearbox although not 100% sure. Car is working fine, could just be something loose but it does sound a mechanical rattle, usually only happens once the car is warmed up.
You should try pressing the clutch while idling in neutral and see if the noise goes away. If it does then it's likely to be the thrust bearing though it could also be the input shaft on the gearbox (not very likely, IMHO).
Post by kenny » Sun Oct 08, 2006 9:43 pm
It still there when the clutch is in, only begin to here it above 15mph ish.
Dont think its the heat sheild, already have a very rattly heatshield but its a different sound.
Post by mac » Sun Oct 08, 2006 10:00 pm
Take a spin past the house one evening this week and I'll lend an ear.
Post by kenny » Sun Oct 08, 2006 10:05 pm
cheers Mac, will do.
Post by mac » Sun Oct 08, 2006 10:09 pm
G72 9NE
01698 825355 - Rules of the house are - if the back doors are open DON'T come into the garden!
