Bleeding Brakes S1
thesurfbus
Bleeding Brakes S1
Post by thesurfbus » Mon May 18, 2015 11:46 am
Any tips I haven't already read about for bleeding S1 brakes? Using an Easybleed and tried rotating front calipers and pushing pistons in/out and there is still air in the system, have already wasted £25 of Castrol Super Dot4.
Lotus Elise 220 S
Re: Bleeding Brakes S1
Post by robin » Mon May 18, 2015 2:09 pm
I find that having somebody bounce on the pedal while the bleed nipple is locked to pump up the pressure in the system helps dislodge stubborn air bubbles. So you lock off the bleed nipple, they pump up the pedal until it is as hard as they can get it, then while they are still standing on the pedal you open and shut the bleed nipple. Repeat. Also if you've fitted new rear pads and the calipers are refitted you should also operate the handbrake repeatedly to crank the rear pistons up to normal position - otherwise the pedal will feel spongy.
2F45T4U
Post by 2F45T4U » Mon May 18, 2015 5:49 pm
As above. Also, get a half decent pedal and drive round for a couple days before giving it another squirt.
Post by Mikie711 » Mon May 18, 2015 11:30 pm
Jack the front up so the car isn't level. Had a bugger of a time after rebuilding the brakes on my S1 and this worked to help get the air out of where ever it was hiding.
thesurfbus
Post by thesurfbus » Tue May 19, 2015 7:40 am
Cool thanks, I had my 9 year old son helping me, and he admitted after to just pressing any random pedal :D
My Ace mechanic is coming round tonight, so hopefully will get it sorted.
Doug
Lotus Elise 220 S
Post by woody » Tue May 19, 2015 8:21 am
My least favorite job ever on the S1 is bleeding the brakes when there's air in the system. I used the shug-sooker(tm) the last time which seemed to be effective. It's a device for sucking oil from the sump via the dipstick tube, but I added a smaller rubber end to mate to the caliper nipples.
Post by mckeann » Tue May 19, 2015 9:32 am
I have a vacuum pump for doing the brakes on my motorbike. Was only £35 on eBay, worked a treat on an empty system.
thesurfbus
Post by thesurfbus » Wed May 20, 2015 9:59 am
Success, it would appear I had actually fully bled the system, however I was using blocks of softwood in the calipers instead of the pads and discs, and it would appear the wood was compressing so much that the pedal was going to the floor.
Just the tracking to set, and BUB will be back on the road :)
Lotus Elise 220 S
Post by robin » Wed May 20, 2015 5:48 pm
LOL wood in not good brake pad shocker ... glad it's all worked out!
Post by alicrozier » Thu May 21, 2015 12:11 pm
Mr Gourlay had a pressure bleeder we used on the Orange Honda S1. I still have a brake fluid stain on my garage ceiling (despite multiple paint overs). Inadvertant blow off...fnarr! :D
Also if using an easy bleed (uses tyre pressure as an accummulator), after you've remembered to deflate the tyre so as not to overpressurise the brake system, be sure not to sook brake fluid back into your wheel. :damnfunny
Or maybe not damnfunny if you're a tyre fitter...
