S1 Door Spring Plate
111Robin
Post by 111Robin » Sat Nov 21, 2015 5:53 pm
Has anyone replaced the door hinge spring plates ?. It's supposedly possible without removing the clam, just removing the relevant screws and pulling it out a bit to get enough room to remove the hinge bolts. Just wondering if its possible solo by supporting the door on a jack or is it likely to end in tears ?.
Cawdors1
Re: S1 Door Spring Plate
Post by Cawdors1 » Thu Nov 26, 2015 2:05 pm
Is this the bit that helps keep the doors open? If so I hope it is possible without clam removal, as mine shut on me head with the lightest of breeze.....Jon
"One Yorkshire Pudding, in a sea of Haggis"
111Robin
Post by 111Robin » Thu Nov 26, 2015 11:10 pm
That's right, its just a plate that the hinge pushes on and passes over to then hold the door open, they're prone to breaking. If I thought I could remove the door I'd do it myself. The parts are cheap from Elise parts if you want to have a go then tell me how you got on :D
Cawdors1
Post by Cawdors1 » Thu Dec 03, 2015 8:30 am
Read a bit on SELOC and many recon even fitting a full rebuild kit makes no difference......so think I'll just jam mine with me head whilst I get out....
111Robin
Post by 111Robin » Fri Dec 04, 2015 5:21 pm
Cawdors1 wrote:Read a bit on SELOC and many recon even fitting a full rebuild kit makes no difference......so think I'll just jam mine with me head whilst I get out....
It depends if the hinge (aluminium) is badly worn where it bears on the plate. If not a new plate will fix it. Mine is low mileage so the hinge is unlikely to be worn so will still have a go if I can get the door off without taking the clam off.
