Toyota Gearbox oil Change
Looking to change out the gearbox oil on my 111R tomorrow for the first time since I got it.
Have noticed the gearbox filler plug is in an awkward position and unsure of the best method to get the new oil in.
Is it possible to feed a pipe past the engine and into the hole? or any other suggestions?
Elise 111R
- alicrozier
Re: Toyota Gearbox oil Change
Remember doing it that way yep, length of tube and funnel.
I poured from the top and 'assistant' held pipe in place and checked fill level.
If you do not have a spare pair of hands use either a very large syringe or attach a tube to the top of the gearbox oil bottle and squeeze it in from below. Mind it does not splash back in face once full:-(
Mini Cooper (wife spec)
BMW dog wagon
BMW dog wagon
What's the recommended oil? 75/90 gear oil? Synthetic or semi?
Tech wiki seems to suggest 75/90 fully synthetic gear oil.
- mwmackenzie
There was landrover oil that makes the change a lot better, don't remember off the top of my head which oil specifically but Ali always used it back in the day to make the yota box smoother.... Someone on here must know or remember having it put in their box??
- alicrozier
RED LINE Synthetic Manual Transmission 90 MT90 75W-90 GL4
http://www.opieoils.co.uk/p-1020-red-li ... 0-gl4.aspx
Cheers guys. Sucessfully changed last week via big syring when i stuck on my new 2bular 7" silencer. Big thanks to Jim there as its everything I hoped for and more.
Also used the redline and it is alot smoother now.
Elise 111R
Good job Ryan, just ordered some gear oil as I've been meaning to change mine too.
