Shug wrote:Righty-ho.
Any more ideas?
Cool, so you didn't need the -12V trick - just as well as that's last resort
OK, so the next question is whether the ECU is actually trying to run the fuel pump. First you need to reinstall the immob bypass connector (or the immob itself if you prefer).
Assuming the ECU works the MEMS (and presumably M3DK) will run the fuel pump briefly at power up. It does this by pulling pin 20 on the MEMS connector to ground. This engages the fuel pump relay in the MFRU and runs the pump.
So you should be able to unplug the M3DK, turn on the ignition, use a jumper wire to jump pin 20 to earth and that should cause a click from the MFRU and the fuel pump should run.
If the relay doesn't click then you have a wiring fault between the MEMS plug and the MFRU or between the MFRU and unfused ignition. I'm sure you have the wiring diagram - it shows all the MFRU pins.
If the relay clicks but the pump doesn't run then you have a wiring fault between the MFRU and the inertia switch or the MFRU and the fuel pump.
If the relay clicks and the fuel pump runs, there is no problem in the fuel pump circuit but rather a problem in the MEMS side of things ... let's get into that only if we need to!
