Hi there. Hopefully somebody can help
ive just completely removed the OEM seat belts and replaced them with shroth harnesses. Im really happy with the install but the problem is that the airbag light has now illuminated and I can't work out why? Are the seatbelt connectors (both on the seatbelt and under the drivers seat) somehow connected the airbag mechanism and what can I do to reset/ fix the problem??
thanks T
Airbag light
Re: Airbag light
Iirc, lotus stopped fitting harnesses/harnesses only when the card went to airbag dash only versions? Think the issue is something to do with the airbag not being calibrated to work with the different position you'd be in during a crash with harnesses.
Re: Airbag light
Presumably it's worked out the seatbelt units are missing. You could try plugging them back in and see if the light goes off, although I'm not convinced the airbag light will reset without manual intervention.
I've got harnesses in mine but left the seatbelts in too. I've unplugged the under seat connection and haven't had any issues. Of course things may have changed since 2013 but I doubt it. Pretty sure Kingers running with seatbelts and harnesses too.
Exige V6
Re: Airbag light
If there were seatbelt pre-tensioners fitted which have now been removed, this will almost certainly be causing an airbag fault.
anthonyyule
Re: Airbag light
Thanks guys.... yes that's the issue. I've fitted resistors into the he seatbelt pretensior plugs but the light is still on so I reckon the ecu will need a reset next time it's at MMC
