Morning all, who in Scotland is able to check over and map a Honda installation. Nearer Aberdeen the better. My conversion is over fuelling and I'm struggling to figure it out.
Honda Mapping
- alicrozier
Re: Honda Mapping
These guys specialise in Lotus and Honda so could be a good option?
I don't have personal experience. Others may have, good or bad?
http://www.cardenmotorcompany.com/
Re: Honda Mapping
As you have a K-Pro Robin that can be hooked up to a laptop with the Hondata software, Ricky Gauld at Bridge of Marnoch is a good friend of mine and has had plenty of experience on both mine and Craig Wallace's cars, and Craig himself is also capable of mapping the K20.
Re: Honda Mapping
I will give Carden a call Ali to check that they can map a K100 ECU.
Ricky can not do this as it requires specialised equipment. Yellow N3 had a K-Pro so no problem.
Re: Honda Mapping
Tut I have a Kpro so Ricky should be able to look at it? Do you have a contact number for him? Prefer to use someone known.
Re: Honda Mapping
01466 780190. Give him my love.
