I'm going to get the elise back on the road
Post by BiggestNizzy » Tue Jul 24, 2018 9:32 pm
After 5 long years of it sitting there doing nothing I am going to get her back on the road.
Thing is she has sat for all that time :(
1. Get the wheels turning
2. Get her started
3. Replace all fluids
4. Get her road legal.
Tonight's job was free off the brakes and try and double check some electrical stuff.
Brakes have been free'd but the plan is to pull the disks off and give them a rub to clear off the rust (MMC's) and fit new pads.
I popped the plugs out to try and get her to turn over but as expected nothing, fuel pump didn't even prime :(
Looking for suggestions on things to check, replace etc. I can see this list getting very long.
Re: I'm going to get the elise back on the road
Post by campbell » Tue Jul 24, 2018 10:19 pm
Bravo!
Stupid question. How's the battery.
Post by woody » Tue Jul 24, 2018 11:37 pm
Alternator will have seized for sure.
Everything else will need checked.
Can swing by after work one evening?
H8OAG
Post by H8OAG » Wed Jul 25, 2018 9:44 am
:popcorn
BMW Z4M40i
Range Rover Velar
2022 Spec Mini JCW
BMW R9T Scrambler Sport
Honda 250 Race Quad
Womaniser Liberty
Post by Victor Meldrew » Wed Jul 25, 2018 7:20 pm
Get it over to Craig Moncrief as a winter project. It worked for Vicky, I never thought she would ever run again. At least your car is still intact with all the bits.
Post by BiggestNizzy » Wed Jul 25, 2018 9:10 pm
I will probably pull the alternator off and rebuild it, a wee job for a rainy day when the kids are in bed.
Cheers, I might just give you a bell when I go to do something big that I can do some major damage too. I am not getting a lot of time do anything right now it's mainly tinkering.
This is tempting, After the tinkering, I might just do that ready for 2019.
Post by BiggestNizzy » Wed Jul 25, 2018 9:12 pm
Tonights tinkering
The battery is probably gubbed, but I expect corrosion of the earthing isn't helping. I connected the jump leads up to the starter motor and I had the fuel pump prime. But only a click from the starter.
Post by Sanjøy » Thu Jul 26, 2018 8:32 am
Woody are you starting one of these threads?
Post by woody » Thu Jul 26, 2018 8:34 am
No, I'm curating a future barn find
Post by BiggestNizzy » Fri Jul 27, 2018 8:07 am
Pulled the starter motor off last night (I really should take pictures) It's in the process of being stripped, cleaned and rebuilt. The brushes look ok as does everything else, unfortunately.
Anyone know who makes them so I can get spares?
It has a rover sticker and part number on it and the but the solenoid has Magneti Marelli written on it.
Edit: After a bit of digging it's a Lucas M78R that is fitted. Everything is stamped Magneti Marelli. The brushes are hardly worn so I will just clean and rebuild.
Post by BiggestNizzy » Mon Aug 06, 2018 9:58 pm
Ok for the past week and a bit, I have been working on the starter motor. Nothing too taxing or fancy so far just a strip, clean, refinish, check, make shiny and fit new brushes. To be honest the brushes weren't in that bad condition but I had to change something to justify the time spent on something that probably worked anyway.
Before
https://photos.app.goo.gl/eg4RtE1t1k4JCmgY8
After
https://photos.app.goo.gl/295NSDDhsnb9A5H77
Post by Sanjøy » Mon Aug 06, 2018 10:43 pm
Shiny.
Post by Stephen » Sun Aug 19, 2018 11:27 am
The alternator tents to have the rotor and stator corrode together. Stick it in a vice and see if it will turn using a breaker bar on the shaft nut.
Post by BiggestNizzy » Fri Apr 12, 2019 9:36 pm
Ok back at this again, starter has been refitted and is now the only shiny thing in the engine bay. Downside is I have forgotten where some of the connectors go so if anyone has any pictures it would be greatly appreciated.
New battery has been fitted, new battery earth strap and new battery terminals. It turns out the positive terminal had corroded in half so cleaned that up.
The starter does fire up (woo) but the fuel pump doesn't prime :(
Finally I have got fat and getting in and out is a nightmare!
Post by Stephen » Sat Apr 13, 2019 8:04 am
Good luck getting it back on the road.
I need to do mine too.
